2006 CBR1000rr, 44 tooth rear sprocket.
Discussion in 'Mods, Upgrades, Accessories and Products' started by Gilmourr, Sep 24, 2016.
  1. Muffking
    Just swapped to a 47 rear on my track bike to add to the -1 front.
    Looking forward to my next track day in a fortnight :D
  2. paullec
    paullec Active Member
    I've gone -1+2. On std chain length. It does spin up a lot faster
  3. Gilmourr
    Gilmourr Active Member
    -1/+1 sprockets fitted, still running my well worn 50 profile rear tyre, gear changes are a little rapid now. Pulls great but think the 55 rear will make it better for the road. Speedo is now 10% out so will recalibrate the Speedohealer after I fit the 55 profile rear.
  4. Voleracing
    Voleracing Active Member
    Supersprox 44T on my 2014 blade (standard 42T)
  5. Gilmourr
    55 rear fitted with the -1/+1 sprockets. Hope I get some dry roads to scrub it in and recalibrate the Speedohealer. Should now only be a 5.6% change in gearing.
  6. Gilmourr
    55 rear feels great. The bike is just falling into the corners now.
  7. SimonRR
    SimonRR God Like
    Good grief, thats 150 max then ;) or do you over rev that thing ;) dont go to a fast track or you will blow yuor engine lol ;)
  8. Muffking
    Probably not far off, although the speedo read 180mph along the park straight :D
    It doesn't over rev as it makes 3rd gear much more useable on the slow bits, rather than how it used to rev out in 2nd just before a corner. I won't find out what it's like on longer straights until I go to a bigger track, but i'm no higher than 5th gear at Cadwell.
  9. SimonRR
    SimonRR God Like
    I have a speedo healer for sale that you need to correct that inaccurate speedo ;):D
  10. Muffking
    might take you up on that at some point, although I don't normally use the speedo on this bike.
  11. SimonRR
    SimonRR God Like
    but it does log your max speed
  12. jgraham562
    jgraham562 Active Member
    Is the setup for an 08 blade the same as pete954's 2012 model?
