2008 post crash rebuild thread
Discussion in 'General 1000RR Discussion' started by Alblade, Feb 18, 2013.
  1. Alblade
    Alblade God Like
    cheers, I did suggest soaking it overnight and wash it over with a soft brush - when he sees I off bike without guard he may thing differently after 60k
  2. Alblade
    Alblade God Like
    Few items purchased today to help with the bodywork fitting planned for next weekend:
    Can anyone guess the cost for 9 clips? They are on sale or return
  3. Andrew
    Andrew Active Member
    £27!!
  4. Alblade
    Alblade God Like
  5. bubba
    bubba Member
    there expensive little plastic buggars arent they:mad:
  6. Alblade
    Alblade God Like
    Those clips were £17
    Will def try the ebay ones, but previously I've never found 'aftermarket' versions actually work - somebody here may know of a supply which does work 100% for half the price.
    THe weird looking one is the centre one under the nosecone which hold the undertray panel in place.
  7. Stefanos
    Stefanos New Member
    why you payed for discs to be repaired when you can buy at that price used OEM ...or with a bit less more (around 250) you could get brand new brake disc by braking?
    i also have few parts to sell for that bike as i turn mine in to Track bike (all my plastics where sold ,and my headlights dropthem off the self ...and broke in 2 :( )
  8. Alblade
    Alblade God Like
    Hi Stefanos
    The disks are brand new at that price from a BSB race team bike via ebay - its easy to forget those disks have been in use for 60,000 miles and while not the harshest rider a few track days, the silt and sludge and other much must have taken their toll - they are still quite serviceable but was getting some judder so having them to hand (bought them 2 years ago) thought it was worth swapping them over.
    There is one headlamp lug missing on my bike but told it should not affect the rebuild too much.
  9. Stefanos
    Stefanos New Member
    oh ok cool couse you sayd repaired and i thouhg you where repaipering the stoc disc
  10. jokeshopbeard
    jokeshopbeard Active Member
    If only somebody could make em as good as Honda!
  11. Alblade
    Alblade God Like
    Got new sticker for the exhaust today so thats another thing sorted.
    Thinking quick action throttle for it as a treat but think my mate will expire with more work lol
  12. Alblade
    Alblade God Like
    quick request - could somebody remove and photograph the bolts / rubber washers etc. which hold the front of the tank shrowd / cover on a 2008+ Blade, bolts lost and need to see what to replace them with
    Also need the 6 fixings to hold the fairing infill panels in place (3 each side) but guess honda only part and about £3 per clip like the others
  13. Alblade
    Alblade God Like
    Few updates here:
    Work in progress - tank / airbox off for plugs / filter etc. You can see the ECU on top of the airbox which had to be replaced
    Don't drop things down these tubes is a top tip (and my mechanic did not so don't worry)
    Airbox internals - it had done about 8,000 miles since last cleaned
    And after works
    K&N filter pre cleaning
    and post
    Clock mount bracket comparison
    Something very large missing from front of bike...
    #33 Alblade, Mar 9, 2013
  14. Alblade
    Alblade God Like
    How it looked this morning on arrival
    Pile of panels and parts to fit onto it
    Smashed up old panels
    Bike pretty much done bar bodywork
  15. Alblade
    Alblade God Like
    Left hand panel 'in place' - as anyone who has removed this will tell you - the 2 multiplugs in the in-fill panels are a real pain, along with the vacume tubes etc.
    Right hand panel in place
    Nosecone and side panel on
    Bike starts and for first time in about 15 - 20,000 miles I have a rev counter and gear indicator
    Pretty much all done
    Radiator was removed and left to soak for a few hours then washed / brushed and blown over with airline.
    Clutch cable replaced and much smoother than old - Old still servicable as a spare - just needs fully oiling from both ends
    Only things left are:
    6 fixing clips to hold air tube in-fill panels on, 2 bolts to hold tank cover on at front and attach a tax disk holder
    Will get some better pictures with it all done - there is one tiny bit annoying me - on the left hand fairing below the light I must have missed a clip and fairing in-fill panel / trim is not sitting flush at front edge of fairing - its just a right pain to remove bellypan, LH inner part, under tray, multiplug, remove fairing to re-seat it - needs a wet Saturday or similar to get round to it!
    Also a sticker to cover the blue Rothmans badge of front mudguard - was going to put carbon on but with while rear hugger it loogs better with white front to match
  16. Alblade
    Alblade God Like
    All - think this may have been lost / missed -
  17. martinowen
    Looks good mate, what do you plan to do with her now?
  18. Alblade
    Alblade God Like
    The 6 clips purchased for 8.50 - 2 rubber collars were another 3.00 each - will find bolts and collar as i am sure I have the 6x22 bolts somewhere from fixings left over.
    Huge thanks for Neil at Hunts Motorcycles and all in the Service department there - really helpful and no bother removing items quoted when I say 'how much for a bolt, I'm sure i've got that somewhere at home' - they supplied the clock bracket of Dunlops race bike, the tail unit from one they had with minor damage from a stock bike and lots of other bits I've prob. forgotten now
    Mark / aka Yorkshire Gooner also supplied the ECU and lockset to get the rev counter and gear indicator working again and small rear undertray part - big thanks
    #38 Alblade, Mar 10, 2013
  19. Alblade
    Alblade God Like
    Finished pics
    Just needs air duct infil panels put back on now, bolts, collars and rubber washes for front of tank and its done and dusted and ready for Scotland in May and the Alps early June
