2012 parts fit 08-11?
Discussion in 'General 1000RR Discussion' started by SilverH, Dec 21, 2011.
  1. Jamiestrada
    Agree on the dash looks great, would of thought they would have kept the harness the same as 08-11 so maybe just a fitting bracket ? Craig might have an idea ?
  2. CastrolCraig
    CastrolCraig Active Member
    No idea on the dash, the sub loom will certainly be different, but i wouldnt want to be the guinea pig on that particular attempt.
  3. Benn The Pig
    For a start the lap timer button is the start button so that's different
  4. CastrolCraig
    The switch will be plugged into front sub loom anyway, so i would assume if you got the switch, dash, front sub loom you may be able to get it lighting up, however if it will function properly is a different matter.
