2017 Fireblade Traction Control - help please!
Discussion in 'General 1000RR Discussion' started by Richinio, Mar 18, 2019.
  1. nevsrevs
    nevsrevs New Member
    Now keep them beedies peeled
  2. nevsrevs
    nevsrevs New Member
    Any updates chaps?
    Pardon the pun
  3. nevsrevs
    nevsrevs New Member
    I’m trying to find the circumference of the 190/55/17 Bridgestone R11?
    Not sure if anyone on here could locate it, I have tried emailing there tech team.
    Be interested to see how close it is to the sp
  4. nevsrevs
    nevsrevs New Member
  5. nevsrevs
    nevsrevs New Member
    This is what got my interest
  6. RC45
    RC45 Active Member
    But its nothing useful.
    No indication of size per bike and response per bike.
    Is this part of a magazine?
    Without bike specific data the video just click bait really.
  7. nevsrevs
    nevsrevs New Member
    The only useful thing is it’s a 55 profile tyre that is track Orientated and I’m trying to work out of it’s closer to the o.e tyre size for another option on track.
    Can’t find any tyre size information online and Bridgestone ain’t playing
  8. nevsrevs
    nevsrevs New Member
    So I’ve put a 190/50/17 on the rear and guess what, false neutral from 5th to 4th not only on my bike but 2 others I’m riding with.
    I thought this was going to be our golden ticket to having the downshift back on.
    Back to using the clutch again. Booooo
  9. nigelrb
    Gee, you've had no end of problems with this. Weird that the standard makes it act up, unless you've changed a heap of other settings.:(
  10. nevsrevs
    nevsrevs New Member
    No mate, just been out again tried turning the quick shifter to setting number 1 on up and down. 5 laps in miss shift.
    The other chaps have turned the down off for good
    Now.
    So have I that was scary
  11. tuktuk
    tuktuk Elite Member
    That was one of the main reasons my mate had his bike replaced by Honda. He kept getting false neutrals, even sent him into the gravel on track, expecting engine braking going into a corner and nothing there.
    That was a 2017 sp and they changed it for an 18 plate bike. Can only assume there was an upgrade whether mechanical of software based when manufacturing the 18 plate bikes.
  12. Kevin1
    Kevin1 Elite Member
    It's a Jonah
  13. nigelrb
    If there was an upgrade, I don't think Honda made anything public. And understandably so!!
    They'd been tainted enough without bring the problem(s) to the public's attention again.
  14. nevsrevs
    nevsrevs New Member
    We are all on 18’s no difference from the 17’s I’m afraid
  15. nevsrevs
    nevsrevs New Member
    So annoying because I love the bike, but can’t use one of its best gadgets
  16. RC45
    RC45 Active Member
    You guys still wont listen. This is not hard to understand.
    The Autoblipper downshifting (separate function to QS up-shifting) is DIRECTLY influenced by actual vs perceived vs calibrated gearing.
    Period.
    Done.
    Complete.
    Finis.
    If you fuk with the gearing in any way then Autoblipper WILL disable itself at the exact moment it cannot correctly determine wheel speed vs geared transmission speed. This is why you may get a few Autopblipper downshifts in before you are left high and dry then it seems to work again.
    This is how Honda designed the system.
    Yes, they screwed us over.
    Yes your ONLY answer is the HRC ECU that gains access to the tire size/sprocket size menus.
  17. nevsrevs
    nevsrevs New Member
    These are standard bikes with standard gearing and standard tyre sizes????
    How can that be correct
  18. RC45
    RC45 Active Member
    Is the tyre the tyre Honda sells on the bike? Is the tyre within their secret margin of rolling circumference range they specificy (being sarcastic here as we don't know what the margin of error can be).
    The lack of Autoblipper behaviour is indicating that there is a math problem with the speed portion of the formal....
    Or..... the rider is not closing the throttle completely.
    Autoblipper will disengage if there re is ANY throttle dialed in during the gear change action.
    QS will be bypassed if the clutch is lever is pulled enough to trigger the clutch position sensor switch during the gear change action.
    In any event, the bike is behaving exactly as Honda intended it to - the real issue is this NOT how we WANT the bike to behave :)
    Honda screwed us over.
  19. nevsrevs
    nevsrevs New Member
    Yes it’s the factory Pirelli sp on the bike.
    As for the other points it’s hard to be 100% sure but in my mind it was closed throttle and definitely no clutch
  20. nevsrevs
    nevsrevs New Member
    So carried out a dtc clear on 2 of the bikes and no more false neutrals for 2 sessions.
    Not sure wether it’s anything we done or just luck?
    But it was happening every few laps for each bike.
