2018 flat battery.. ?!
Discussion in 'Maintenance' started by Lacon, Mar 21, 2019.
  1. Lacon
    Lacon New Member
    Quick update.
    It was the tracker that drained it - without line of sight it was just constantly pinging away.
    Re the stuck bolt, Honda Assit fella had to use a chisel to get the bolt undone but managed it without slipping and scratching the paint. Heart in moment that. It had been massively overtightened at the factory / garage.
    Luckily the blade battery is easy to remove (once stuck bolts taken care off) so is now charging and I’ll hopefully be back on it tomorrow.
    Of note, I don’t have electrical sockets in my garage but the mechanic recommended getting a car battery and hooking that up if you’re leaving it anymore more than a couple weeks.
    Seems pretty straightforward and simple solution. He was a biker himself (with a 1999 and 2012 blade) said that’s what he does for his.
  2. nigelrb
    Good result!!
  3. roboticus
    roboticus Active Member
    my tracker used drain mine on my ninja if left for 2 weeks, never again
  4. MikeOC
    MikeOC New Member
    Honda fitted a NOCO charger point to my bike......
  5. Lacon
    Lacon New Member
    Interesting - I’ve got one that I take when touring. May ask them to add one on the first service in a couple of weeks.
    Going to ask them to fit the tail tidy I got as well - after the issue with the bolt i’d rather save my time.
    One thing I forgot to mention earlier was that most of the tools are missing from the blade tool bag that comes with the bike - only realised when I was trying to remove the seat.
  6. nigelrb
  7. Kevin1
    Kevin1 Elite Member
    You don't mention if the 2018 is an SP or not. If it is, you'll need a special Lithium charger.
  8. nigelrb
    Given the avatar is Matte Black, I'd say not.;)
  9. bazzashadow
    bazzashadow Elite Member
    This has helped me.
    My mate brought a new blade last week and today his battery was dead.
    No tracker
    He got told by the dealer to get it to them and they will have a look and told him it had a lithium battery so don’t jump it or use any old charger, I told him it had not got a lithium, he went to infinity for a lithium charger and they sold him a normal one and after all that he just stuck it on anyway and then checked the battery number and it is a normal battery.
    So it is on charge and then going back to dealer when charged.
    Do you get my jist;)
  10. Lacon
    Lacon New Member
    Yeah - dealer told me mine had a lithium-ion battery but it’s just standard. SPs have the lithium batts.
    Standard battery is pretty small - half the size of the one I had on my little NC30. I actually don’t think I’ll bother upgrading to a lithium ion one
  11. Jez
    Jez Senior Member
    My solar charger has not let me down, It charges 2 bikes lithium bats at a regulated 13.4 v both have alarms. they hibernate all winter apart from stripping down and always start.no need for sockets or fancy chargers
