ABS Removal-Honda 1k SP 2014 How To
Discussion in 'Mods, Upgrades, Accessories and Products' started by Gligoric, Feb 28, 2016.
  1. ColinBR
    Absolutely.
  2. Gligoric
    Gligoric Active Member
    I finally removed whole system following the instructions from previous posts.
    And here are pictures how does it look to do it :) WP_20160406_20_50_26_Pro.jpg WP_20160406_20_52_52_Pro.jpg WP_20160406_20_53_52_Pro.jpg WP_20160406_22_45_17_Pro.jpg WP_20160407_13_41_05_Pro.jpg WP_20160407_13_41_14_Pro.jpg WP_20160407_13_41_31_Pro.jpg
  3. ColinBR
    Have you lot figured out how to switch the light out on the dash yet??
    :p
  4. ShinySideUp
    ShinySideUp Elite Member
    Erm...miby..........:D
    Oh an u can put your bike back together yourself mate I done my job!!! ;):D
    Remember.......
    #24 ShinySideUp, Apr 10, 2016
  5. ColinBR
  6. Gligoric
    I have ABS light on,but I don't mind :)
  7. ShinySideUp
    Colin's abs light is now always off as he did mind!
    I didn't even remove and open the dash either! ;)
  8. graemewalker
    graemewalker Elite Member
    Yes it's like a warrens nest abs shit never ever again well not combined abs anyway
  9. JP3
    JP3 New Member
    Hello, a couple of questions guys if you don't mind. Will the ECU be disgarded and removal and whats the purpose of cutting the wires if they are to be removed.
  10. Dave dunlop
    Dave dunlop Elite Member
    Spill the beans laddy! Mines out but still interested in knowing what makes it come on and stay on. I'm gussing it picks up some voltage once the system self checks to turn the light off??
  11. ColinBR
    Yea your right in what your saying mate. He just found out what voltage it needed and tapped into another supply with the same voltage to switch it off.
  12. Dave dunlop
    Colin do you know what voltage is required and what he tapped into?
  13. ColinBR
    Afraid not mate.
    I was 150 miles away in Aberdeen when he did his wonders on the bike
  14. JP3
    JP3 New Member
    Woh, is this for the 2014 model only....
    #34 JP3, Apr 29, 2016
  15. ShinySideUp
    The abs ecu will be completely disregarded and the cutting the wires is required in order to remove the abs part of the wiring loom from the non abs part of the wiring loom, as the non abs and the abs wiring looms are slightly altered by Honda to add the required fuses and connections and allow for bigger battery fitment.
    The abs on the blade/cbr600rr is fundamentally the same throughout all abs equipped bikes from launch in late 09 to current.
    Oh an way to introduce yourself buddy. ;)
  16. hessel
    hessel Member
    old threat but i just thought i reply to add my 2 cents..
    the only thing u have to do to turn off the abs light after abs removal is cut the orange/green wire (running from the abs unit to the dash) and attach the bit on the dash side to ground....
  17. Lozzy
    @Dave dunlop
    Dave, how long did it take you to remove the system? I might have to go down this road & just want a rough idea hours wise so the garages don't try & stiff me when I make cost enquiries....
  18. ColinBR
    Took me about 6 hours to remove it all
  19. Lozzy
    Thanks for that...much appreciated. Did you upgrade your brakes at same time? Or stay standard? Any issues since you did it?
  20. Dave dunlop
    Yeh Colin's about right, at a steady pace with lots of tea breaks:D if I had to stick my neck on the line I think 5 hours with a few less brews, that would be to reconnect with lines and re bleed.... or you could just disconnect everything and leave it in place! Can't see the point in that personally as it removes a shed load of weight, your need to make a bracket to strap the battery up as it's removed from the pump under the seat... :)
