ABS Removal-Honda 1k SP 2014 How To
Discussion in 'Mods, Upgrades, Accessories and Products' started by Gligoric, Feb 28, 2016.
  1. ColinBR
    I upgraded to brembo callipers and master cylinder.
    Zero issues since and wished I'd done it sooner
  2. Lozzy
    Cheers Dave.....I know it weighs heavy I remember seeing a photo of it all that you posted up :eek: so I'd want it removing. Just needed a rough idea of labour time so they cant have my pants down!
    I had a conversation at the dealers the other week with Honda's version of Alan Partridge regarding the new Blade & costs of bleeding the new abs system v the old system....it would have probably been less painful drilling a hole in my head :confused:
    I think he coughed to it being about 3 hrs labour for the new one!
  3. Lozzy
    Thanks for that....I'll be keeping mine a few more years so I'll look at that upgrade if I get it ripped out.
  4. ColinBR
    In all honesty a master cylinder and brake lines with the standard callipers is more than enough. I'd put the cash for the callipers elsewhere like a quick shifter
  5. Dave dunlop
    Dave dunlop Elite Member
    Your welcome, agree with Colin on the OE callipers, I opted to change mine out to the Brembo GP4's RCS MC and Brembo T Drives.... mega setup but real overkill for road use, just stick with your OE callipers with some new lines and your be sorted:D can't stand all that main stealer bullshit! Half the time they haven't a clue! Some of the stuff I've seen come out of my dealers is hideous!!
  6. Unity
    Unity Active Member
    Why do you guys buy an ABS bike if you don't want ABS? I'm curious what is your reason for removing the ABS? Surely it can help you stop quicker in an emergency?
    I've never had my front wheel lock on a superbike on tar, but have had the rear lock many times. I release then reapply but I'm sure an ABS system could do it faster and more effectively than me.
    I've always been afraid of the front locking up under heavy braking, expecislly on damp/wet roads. But its never happened. I imagine ABS would remove some stress about that.
    #46 Unity, Apr 8, 2017
  7. Lozzy
    I bought mine, not realising there was a fault with the Honda abs system, I guess the others who've removed it were the same. Having the brake lever come fully back & nothing happen is pretty unpleasant...it's happened 5 times now in 3 years. 2 of which has occurred in the last 2 wks & the cost of having the system bleed is expensive. There's a big thread on here on the issue somewhere.
    • Agree Agree x 2
  8. Unity
    Unity Active Member
    Wow Lozy, that's pathetic that Honda didn't get it right or at least recall the bikes and remove the ABS for you. You're lucky to still be here!
    I've only heard got things about Honda ABS until now.
    I would do the same.
  9. stupot
    stupot Active Member
    Without trawling through the pages, my mate has got a 16plate sp which he bought with 1000 miles in the click, we were out this morning and he must of had a moment as he didn't look happy.
    He isn't a person who mods bikes to much apart from an end can.
    Is it possible to drain the system the unplug a power feed to the abs system. Then just fit a normal brake line set up
    I presume the master cylinder is a normal one
  10. FirebladeRR
    FirebladeRR Active Member
    Panicking a bit as just cut the wires as above picture but wiring diagram says the orange And green wire goes to instrument cluster and the orange And black goes to a fuse then ignition switch? Did I mess up?
  11. kevin nichol
    kevin nichol Active Member
    I am in the process of removing all the ABS Components from my 2015 SP. I've removed all the mechanical components, but struggling with removing or separating the ABS harness from the main harness. Any help on correct way to complete this would be much appreciated.
  12. mgoode180566
    mgoode180566 Active Member
    Did you get it sorted ?
  13. kevin nichol
    Yes thanks I think so. Cheers
  14. mark higginson
    mark higginson New Member
    hi mate how did you do this
  15. nigelrb
    Don't expect an answer. The 'shiny one' has burnt out and hasn't been on for a couple of years.
  16. Lozzy
    I'm in touch with Graeme but he might delete me if I mention ABS to him lol....
    Might be better pm'ing ColinBR or Dave Dunlop
  17. Boothman
    Boothman Elite Member
    So pulling the orange/green wire out of the plug on the clock side and connecting it to ground hasn’t killed the light? That’s weird as its worked for others, although for some it never comes on and others it comes on for the first 20 or 30 yards
  18. mark higginson
    Done it today mate and yes NO light comes for about 2 secs then off. Cheers mate
  19. paul1966
    paul1966 Active Member
    later bikes come with abs full stop. ( and the earlier Honda is bad) . and if youve ever had them fail you would understand either removal or bye bye bike
  20. Xrayhonda
    Xrayhonda New Member
    Just wanted to say thanks to everyone that contributed to this post.:)
