ABS removal
Discussion in 'Mods, Upgrades, Accessories and Products' started by RepsolPaul, Jan 6, 2015.
  1. Wolfmancol
    Wolfmancol Active Member
    Thank you for the replies. I will check with my insurance first before removing C-ABS and going standard on the brakes then go for an MOT as ran out over Christmas and need to get back on bike. MOT Didn't realise last year as they don't ride bike and check if light goes out then comes back on when braking! All i need now is how to get rid of the pesky ABS light as someone mentioned it stays on after C-ABS removal.
  2. Kieran Hatton
    Kieran Hatton New Member
    Mega useful, thanks!
  3. Claude
    Claude New Member
    It can be done. I had it removed from a 2008 cbr1000rr. The only issue the ABS light remained on after the removal and the rear brake did not activate the rear brake light but the rear brake light did work with the handle bar brake lever. Removing the system shaved 12 lbs off the bike. The task of removing the ABS system was done by Attack Performance in Southern California.
    • Old Old x 1
  4. Alexvaldes31
    Alexvaldes31 New Member
    Hi, i know its an old thrrad but how can i turn off the abs light on the dash board ?
  5. Zapada
    Zapada Active Member
    • Optimistic Optimistic x 1
  6. Andropheonix
    Andropheonix New Member
    Completely forgot about this! Still meaning to remove my ABS, after my lever came back to the bar and I almost jumped a red light at a crossroad I pulled the fuse out, brakes aren't great though. I'm not very tech savvy at all when it comes to bikes, after 8 years of riding I only learned how to tighten the chain a few months ago... how much do we think a mechanic would charge to do all the work? I'd rather pay someone to do it than attempt it myself as my bike is my only form of transport, wouldn't be ideal if I couldn't get to work! I'm pretty sure, even though I was told they'd just remove it for free, I'm not sure they were aware of how much of a job it is, it's also been a long time so it's unlikely they'd remember...
    Cheers all!
  7. mk3golfcab
    mk3golfcab Elite Member
    I’d imagine at least a days labour for a garage at £45 per hour plus VAT? That would be a guess from an uneducated fool at a private garage, not a dealer.
  8. Pete1987
    Pete1987 Active Member
    After 13 years, I am finally ripping the ABS out, did anyone do a step by step guide, so far I have the ECU removed.
    Where does the normal blade ECU live then?
  9. Zapada
    Its under the tank ontop of the airbox.
  10. Pete1987
    Ah Cool, is there a written up guide as i am at a point to start taking stuff apart, how do you tldrain the fluid out before hand?
  11. Zapada
    I am sure there is a guide in the forum please do a search. Now you will not be able to drain the whole system dry. Try to drain as much as possible. The plumbing is easy to remove as well as the abs harness and abs ecu. The issue you will face in under the exhaust outlets where one of the abs pump its located, with a bit of patient you will get it out.
  12. Pete1987
    OK nearly everything removed but how the hell do you get to the back bolt of the front module (the one behind the headers)
  13. Zapada
    Long T handle and patience :)
  14. Pete1987
    The bolt is behind though? I can barely get my fingers to it let along any long tools?
    • Old Old x 1
  15. Pete1987
    I have everything out now.
    Does anything have to happen with the loom I have removed the entire thing, does anything need to be stripped out and reconnected at all?
  16. Boothman
    Boothman Elite Member
    You’ll want to stop the ABS light in the clocks from being permanently on……
    NOTE - Make sure to earth the clock side, not the loom side :)
    #136 Boothman, Apr 17, 2022
  17. Pete1987
    Just done that bit, now to. Reassemble, do the blue and white wires need to be connected together, just looking at it with two wires cut looks wrong
  18. Myblade
    Myblade New Member
    All those wires do is go into the combined abs control unit/ecu which in turn connects the front and rear power units. As all these units have gone the blue and white wires are now redundant simply leave a couple of inches of wire then wrap with loom tape to the remaining wiring. This is what i have recently done having ripped out the abs system completely.
  19. Stuart Gould
    Stuart Gould Active Member
    Thanks to everyone in the this thread/forum, I've just finished removing my ABS system having suffered from a terrifying lever to bar moment at 3 figure speeds. 20220427_134030.jpg 20220427_134110.jpg Anyway, system removed and HEL braided lines now on. Will take it out for a maiden run this afternoon but can't wait to feel the weight and braking difference. Couldn't have done it without this forum, so much good advice to read through.
    • Like Like x 7
    • Downvote Downvote x 1
  20. Myblade
    Myblade New Member
    20220423_173934.jpg Well done. Do you have a picture showing how you routed the front brake lines. I haven't got that far yet as I'm modifying the front end of my bike and mine will kneed to be longer than std.
