ABS removed.....the light !
Discussion in 'Maintenance' started by mgoode180566, Nov 22, 2018.
  1. dgr
    dgr Active Member
    Desborough. Lived there all my life.
  2. mgoode180566
    mgoode180566 Active Member
    somebody has to :D
  3. dgr
    dgr Active Member
    There are worse places. :D
  4. Zapada
    Zapada Active Member
    i cant find the green orange wire on the left plug near the radiator. I found one that is green pink. Any advice?
  5. mgoode180566
    It's orange with green flecks
  6. mgoode180566
    On the large square connector
  7. Zapada
    Is this one? Or the one behind it?
  8. mgoode180566
  9. mgoode180566
    Can you see I have cut the orange/green wire?
    The clock side is connected to earth, you will find a couple of green wires in the same loom connected together
  10. mgoode180566
  11. mgoode180566
    Connected to earth
  12. Zapada
    Yes i found it thanks. I will try to cut from the other side of the plug towards the cluster.
  13. mgoode180566
    Have you removed all of the hardware?
  14. Zapada
    Not yet trying to figure out how to remove the modulator behind the downpipes. Any suggestions?
  15. mgoode180566
    I was stripping all mine off anyway so I removed the radiator and header...be careful of seized studs on the header, I snapped one, a world of pain!
  16. Zapada
    Nightmare. I read on the abs removal thread that you need to utilise the 2 existing plugs needed to power the starter motor from the abs loom. So to recap i need to perform the removal of the hardware then utilize the plugs and finally modify the front loom for the abs light?
  17. mgoode180566
    That is correct, modify the loom to continue to provide power to started solenoid, cut the wire from the clock and short it to earth and remove all of the junk hardware or only the bits ypu want to remove, that is up to you
  18. Zapada
    Did the abs light modification today and it worked great. Is it supposed to stay off during initialization once i switch on the bike? Basically now is off all the time.
  19. mgoode180566
    I believe my light illuminates for a couple of seconds as the systems initialise, then stays off.
    You connected the orange/green to a green earth wire ?
  20. Zapada
    Yes i did but mine stays off all the time. I connected the orange green to the thicker green as shown in the picture you have posted previously. However i have removed the abs fuse. I am guessing thats why the light is off. Update: i have plugged in the abs fuse but the light is still off.
    I forgot to mention that i did not remove anything from the abs system. Only the fuse and the brake lines.
    #60 Zapada, Dec 23, 2018
