ABS vs non-ABS
Discussion in 'General 1000RR Discussion' started by sauluk, Aug 22, 2014.
  1. PeteN
    PeteN New Member
    wow! quite an indictment... and consistent with lots of other google chat... thanks for your quick response.... i guess i'll pull the fuse then... many thanks
  2. Boothman
    Boothman Elite Member
    & welcome to the forum
  3. CalRR
    CalRR Member
    I'm picking my 2010 blade up from the workshop tomorrow as it's just had the abs removed because it was a death trap. One minute I pull the front brake lever and I stop, the next time I don't......I couldn't put up with it any longer so it's gone and braided lines have been added to.
  4. Boothman
    Smart move mate
  5. CalRR
    CalRR Member
    Boothman funnily enough I took a snippet of some advice you posted a while back about the abs regarding the light on the dash. Gave to the mech and he's sorted it, no abs light :)
  6. nigelrb
    Game move:D;).
  7. Slick
    Slick Elite Member
    Just to add the mods I put in to attempt to resolve the issues
    countless ABS bleeds,calliper/rotor services!!!!!
    Braided lines,
    Updated ECU 2012
    Stainless steel pistons
    UHT Race Brake fluid
    Ktech Suspension
    Uprated charging system - battery, stator
    Brembo RCS19
    Brembo Discs/new OEM discs
    new abs pump modules main and front
    heat protection film on front module
    When the ABS is on form I can outbrake most on the road, when not time to clean the leathers!
  8. PeteN
    PeteN New Member
    jesus... you went to town on that... can't fault the commitment.... shame honda didnt try that hard
  9. bonjo
    bonjo Active Member
    When it comes to riding/ driving and cooking, I like it and keep it very primitive. No doubt my next one will have the obligatory ABS an god forbid TC.
    Curious to know:
    For those who have changed to ABS bikes, how does this affect your riding?
    Did you have problems with locking up under braking before? Or any other issues that ABS has solved?
    Or do you ride faster into a corner or closer to the vehicle in front; rely less on your riding skill/ experience amd more on the ABS?
    Or you feel more comfy having less to focus on when riding?
  10. Slick
    Slick Elite Member
    Started off on a non ABS, did everything right , loading up the fronts first then progressively harder braking. Brain continuously assessing road conditions etc
    You find that on an ABS you brake late and hard , as there no linear feedback you end up being quite binary. Braking zones become super late
    Found myself riding a little faster in traffic than I should knowing the ABS would just sort it out, just panic brake when you need to.
  11. bonjo
    bonjo Active Member
    Very interesting comment. Specially the point about the feel.
    I have noticed that in my car (1st with abs) to some extend and very pronouced on snow & ice: the feedback when the wheels are about to lock up is not there and only the buzzing of the pedal tells you you have locked up!
    I guess it must be a lot more pronouced on bikes and I know I won't like it until I get used to it:(
  12. Andrew Bruce
    Andrew Bruce New Member
    Have you ever experienced the ABS fade issue? Just asking as I’m picking up my 2011 C-ABS Blade on Tuesday and all I’ve seen is horror stories about them
  13. Lozzy
    Remals not been on here for 3yrs mate.
  14. Andrew Bruce
    No probs, I did t even notice lol
