Accossato / Brembo MC brake fluid reservoir Help
Discussion in 'Mods, Upgrades, Accessories and Products' started by dan.1moore1, Nov 29, 2011.
  1. CastrolCraig
    CastrolCraig Active Member
    Dam i want that underslung caliper Bracket
  2. arthurbikemad
    lol its on its way to me soooon, the mount by CZ and the HPK caliper! I have a relocator for the Nissis caliper but I find it a bit of a pain in the arse and it dont match the front...lol Bats when its done mate I may start a thread with some of the many pics I have rather than keep stomping on other peoples threads like poor Dan.. SORRY Dan!
  3. CastrolCraig
    Arthur, do you happen to have a pic of the one you have currently, if not are you going to sell the bracket once your bling one arrives?
  4. dan.1moore1
    Ic seen brackets for sale somewhere .. Must have been Ebay as thats the only place i shop lol
  5. arthurbikemad
    Yes here you go:-
    In production
    Mine
    Note: orange pain in bolt head NOT rust.. you can take things too far you know!
    You can get them from FP Racing in the USA they only made a limited number and there are two types one for the better (older) 04-05 caliper and one for the 06-10 caliper you can fit the older larger caliper to later bikes but you need the 04 mount and of course the caliper take into mind the lines are also different for each. The braket is much more than just a bracket as its part of the caliper, the OEM mount is OTT on Honda's part imo but hey thats what they did. Mine is sold to a mate and is number 07 of however many was made but he may pull out, they cost £160.00ish to the door inc line.. I think! I will check.. Its total bling imo but can make it easy to remove the wheel but in the real world...maybe no diff to before, it does lower the mass however..
    #25 arthurbikemad, Nov 30, 2011
  6. dan.1moore1
    I would love that but 180 bucks ?
    Where is Colin ? ha ha
  7. arthurbikemad
    I lie it was $145.00 plus $65.00 for the line so £160.00 ish and this one did not get taxed! You can't put a price on Bling Dan...lol
  8. dan.1moore1
    Thats true mate . Iv been thinking long and hard about how far to take my bike mod wise and after seeing your bike and the reaction it gets every time you post a pic , I have decided to follow your words of wisdom and build my dream bike at least once in my life , so this will be it .
    Ill have to slot 1 of these in but eventually i want after market callipers . If the above bracket is for the stock caliper and you are buying a brembo bracket for your new calliper then do i also need a different bracket if i went for say AP Racing callipers or any other aftermarket brands ? or will they fit the bracket for the stock calliper ?
  9. arthurbikemad
    Oh Dan thats the way my man, who said dont trade just upgrade was right on the money...lol
    The sad thing is most performance parts dont just fit together, there is always something to cause a problem and sometimes to move forward you take two steps back! Like my T drives with the OZ wheels they run a little close to the caliper body, OZ give you spacer rings to run two offsets with this front wheel and two models of bikes so I am lucky in that I can trim down the spacer ring to get an equal offset in the caliper body, Brembo do say I can have 0.70mm but I like to get it as near to perfect as poss, the answer in my case lays in small bits of paper...see...lol
    shows clearence and space between body and disc, shows results with .5mm off the spacer ring! Looks good, 1mm goes neg way! (and all coz some little bald pl#nker wants 5.5mm disc's)
    As for your question most Brembo rear calipers for example have an 84mm spacing from bolt to bolt and the offsets are the same from one model to another so most brackets can be used with a number of calipers like the HPK caliper is the same fitting as say OEM 1098 so yes some can be mounted to the same bracket, as AP racing is part owned by Brembo you would hope they run the same kind of standard? With out looking it up I can not say for sure.. Anyway anything is poss mate with the likes of say Colin around... Take into account that your wheels may use a hub that does not match up well with the OEM wheel, how this you ask? Well aftermarket wheels may be a swap out for the old ones but spacers and offset can be out by small amounts! Hence why I have the problem with the GP calipers, the OEM calipers have enough room for a bus unlike the GP ones, I hate to say most of the time mate its a suck it and see kind of thing! :) I had to make the front wheel spacers to work with the Ohlins forks and now custom made disc spacers to replace the OZ ones, simples....lol :S Always happy to try and help out if you need to ask mate.. :)
    #29 arthurbikemad, Nov 30, 2011
  10. kpone
    Definitely Jesus...
  11. arthurbikemad
    lol nuh not at all mate just some bloke in a shed-ish.. who likes bikes.. :)
  12. kpone
    That's just what Jesus would say...
  13. CastrolCraig
    just looked up fp racing, there age only shows folding levers? have emailed them anyway
  14. arthurbikemad
    Yes thats them his name is Mike he will help you out, would love to sell you.mine but my mate will kill me, you see you'll get one and he'll say he dont want it!
    Posted on my HTC Sensation with Tapatalk
