Akrapovic upgrade and now the engine hunts........??????
Discussion in 'Mods, Upgrades, Accessories and Products' started by PeterT, Aug 27, 2011.
  1. PeterT
    PeterT Active Member
    what is rcs?
  2. fisher
    fisher Active Member
  3. PeterT
    Cheers, what ratio? Also should i install a two line brake
  4. fisher
    I bought the ajustable 18 or 20 ratio
    I'm running two lines on the front and set it at 20 ratio.................its like throwing a parashute out the back when you brake
  5. PeterT
    Is that the expensive one?
  6. PeterT
    And did you upgrade the lines also?
  7. Bikeracer1098
    Bikeracer1098 Active Member
    Dont bother paying the extra for the RCS.
    Just go for the Brembo master cylinder with a fixed ratio of 20.
    Also get some braided hoses fitted.
  8. Bikeracer1098
    You need to get your bike set up on a dyno, there is no way that the bike should feel faster/make extra power with the baffle in.
    The baffle will reduce the output of the bike.
    Get it booked in for a dyno run.
  9. PeterT
    It felt a 100% better with the baffle in so i do not see the point of spending more money on a dynoe run?
  10. fisher
    Yeah I took the braided lines off my older Blade [07 Model] and fitted them to the new one
  11. PeterT
    I will get some Venhill lines then as they are only down the road to me.
  12. dan.1moore1
    Because it will feel better again
  13. JM1
    JM1 Active Member
    LOL. That's because the stock fuelling is better suited to baffle in.
    It would run well with baffle out, but needs a Power Commander map to do so.
  14. JM1
    JM1 Active Member
    That's a pretty blinkered view and not necessarliy correct at all :)
  15. Bats
    Bats Active Member
    I fitted the pc/lambda eliminator and k&n before my exhaust the bike is good standard but like all bike once that pc elim and filter is done the differance is amazing then comes the exhaust for a few more ponies and a mint tune ;)
  16. zeepony
    zeepony Active Member
    I rekon if you dyno'd a standard bike with standard can, it would have higher bhp than an Akra with a baffle...
    There, thats thrown the cat among the pigeons.. FIGHT FIGHT!
  17. zeepony
    Dude, most things on the internet are not necessarily correct at all! :)
  18. Bikeracer1098
    Any aftermarket can with a baffle installed produces less power than the standard Honda can.
    Speak to any dyno tunning company and look as some dyno graphs.
    Yes using your words " you have a pretty blinkered view".
    In future please do some research prior to posting incorrect comments!!!
    Also thanks Chris for the clarification.
  19. JM1
    JM1 Active Member
    OK mate, I'll bite (just a bit though) :)
    Your original statement was that the baffle will reduce the output of the bike. You meant in comparison to the race can with baffle out as that's what the thread's about.
    But any exhaust will only perform well if the engine, fuel and intake systems are setup to suit it. Do you agree with that?
    Also, an open pipe may well give a couple of BHP at peak, but maybe it will have a detrimental affect in the low and midrange, which may be corrected by fitting a baffle.
