And another bike died thread!!
Discussion in 'Maintenance' started by F1reblade, Jul 19, 2014.
  1. masterblader
    masterblader Active Member
    On later blades the stator problem was resolved but ran into other problems like heavy oil consumption which to me was unacceptable when Honda quoted 800 per litre was acceptable well in their books.
  2. scooby
    scooby Elite Member
    well theres your problem......
  3. F1reblade
    F1reblade Active Member
    Damn it, I love the blade but I might have to look at a different bike then.
  4. bandit_287
    bandit_287 Active Member
    I faced the same dilemma last year but in my bikes defence the only problem I've had with it is the stator issue. Bought it on 8.5k and it's now done 22.5k. That's in over three years of fun riding. I've spent loads on bits and setting up the suspension and PCV so in the grand scheme of things I thought it was width spending the money on.
  5. F1reblade
    Yep having thought long and hard about it I think I'll buy the upgraded flywheel and stator as I love the bike and it's the first time it's let me down. I don't suppose anyone knows the parts numbers for the upgraded parts by any chance. I just need to work out where to get them from now. We don't have an abundance of dealers left in the north east :)
  6. dave d
    dave d Elite Member
  7. martinowen
    Have a word with MrB mate, he works at a dealer and sorted a decent price and quick post
  8. F1reblade
    Thanks Martin, is that his forum name.
  9. bandit_287
    Part number for the matched pair from Honda is 06311MEL305. £280.01 plus VAT.
  10. F1reblade
    Cheers Bandit. Got them for that from David Silver spares and some liquid gasket. Now all I need is a flywheel puller to get the flywheel off unless someone tells me it's easy to do and I don't need a tool to do it?
  11. masterblader
    The rotor is on a taper a gentle tap on the sides should release, there is no woodruff key like the earlier blades. Bolt the new rotor on but don't tap the replacement as it would lose its magnetic strength.
  12. F1reblade
    Thanks masterblader I appreciate the advice. With regards the liquid gasket is it a case of simply squeezing it on or use a toothpick and put a tiny smear on? I've also ordered a paper gasket and so now I'm wondering which is best to use?
  13. masterblader
    Both crankcase and cover need to be clean and dry so gasket sealant can adhere to the face area. Small smear of sealant on the both sides to form a seal when torqued up
  14. F1reblade
    Thanks for that, I've cleaned it as best I can with a Stanley blade. After searching the net and manual there appear to be different torquing values for the engine case bolts. I'm going with 9 ft lbs.
  15. masterblader
    On most cover bolts torque is 12 Nm, the manual on the 2004-07 does not list cover settings. Don't have the settings in ft/lb
  16. F1reblade
    12 Nm is 9 ft lbs, so I'm on the right lines. Thanks very much, just got to wait three weeks now for the parts to arrive lol
  17. F1reblade
    New stator and flywheel arrived today and installed. I'm struggling a bit to see the change in voltage when over 5k revs due to my mutlimeter being pants lol. I suppose I'll have to see if the bike dies again and at least this time I'll know it's the reg/rec.
  18. garethS
    garethS New Member
  19. mJZ
    mJZ Active Member
    Interesting post. Not the first time somebody says about reg/rec failing in those bikes. Having a spare one with me at all times might be a good idea.
    I'm quite tempted to get one of those upgraded stators and flywheels as well. I've never replaced flywheels though, I always thought I needed a special key for that.
  20. F1reblade
    In the end I got sick of waiting for the special tool to come from the US (it still hasn't) so I went to the local fasteners and bought a M20 bolt with a right hand thread. Job as they say is jobbed :) £3 can't say fairer than that.
