They don't look too bad for the money Barry, only problem is they only list up to a 2010 model and mines a 2012? Also the picture shows the reservoir bottle just zip tied on to a bracket? Is that how the finished article is left then?
Barry, where abouts does the OEM brake switch attach on to those? From the pics it looks like it does away with the brake switch like most aftermarket rear sets do. Guessing this is from a display bike as the lever is wired in place too! How does the OEM reservoir fit onto the stock rear sets? Guessing some sort of bolt n bracket system but can find a clear picture of just the reservoir showing enuff detail!
Mines not like that at all, it is secured to the rearset. I'll get up a picture showing it but it is secured to the rearset as I had to unbolt it when I did the full C-ABS brake bleed.
I like those Colin; quite different design wise. In the most rearward position, do you know how much further back the footpegs sit when compared to the oem setup?
I'm after something which is a bit lower than standard. Not keen on the Rizomas looks TBH and they don't look like they offer much adjustment either?
