Are you 15 Stone and wanna set up your suspension?
Discussion in 'General 1000RR Discussion' started by exuptoy, Mar 26, 2015.
  1. exuptoy
    exuptoy Elite Member
    After the last comment here I thought I'd check the manual to confirm the tyre size. It says Dunlop Qualifiers as standard but 190/50. Mine is running a 190/55!:)
  2. Mr OCD
    Mr OCD Well-Known Member
    I can't tell you that ... they won't work for you :p :D
  3. exuptoy
    Why, I'm only big boned! :)
  4. Mr OCD
    Front Preload - 38mm (8 turns)
    Rear Preload - 33mm (5th notch)
    Forks dropped 4mm in yokes
  5. exuptoy
    Oooh! This looks promising.:D
  6. Mr OCD
    Rides like a dream ... :)
  7. exuptoy
    What did you end up with on the adjusters?
  8. Mr OCD
    Front comp - 2
    Front rebound - 2 1/4
    Rear comp - 2 1/2
    Rear rebound - 2 1/4
  9. exuptoy
    Not far from standard then.
  10. Mr OCD
    I can't remember what the standard settings are ... But it's convinced me having the bike more compliant for the road is the best thing once sag is setup ... No longer does the bike want to stand up when hit bumps mid corner ... It instead absorbs the bump.
    For track I will dial in more compression but for road work those settings are bloody good.
  11. graham58
    graham58 Member
    Think I need to go on a diet
  12. Mr OCD
    Amazing how much of a difference 2 turns of preload can make ...
  13. exuptoy
    My mate turned up when I was playing with mine last week then fetched his K5 1000 down for me to sort. I was seeing 24mm rider sag at the rear and front preload was showing minimum at 5 ring where standard was 4!!! Compression was backed right off at 15 and rebound at 8. Dialled in 32mm front and 30mm at the rear and adjusted his R&C until it seemed right he couldn't get over the difference. Reckons he had to force it thought the turns before and it felt like it continually wanted to tuck. Now feels amazing!! :)
  14. Mr OCD
    Even a bit more preload wouldn't be a bad idea... aim for 35mm each end ... :)
    I'm actually a bit less in rear and bit more in the front to keep the bike balanced. I am still experimenting though but found even on the standard front preload setting the bike feels planted.
    Raising the rear made the biggest difference....
  15. Mr OCD
    Did Dave actually recommend stock position preload at the front?
  16. exuptoy
    Nah fella, I told him it was showing around 38mm and his advise was to leave it there as I had it.
  17. Mr OCD
    Obviously just the way he worded it ... I've gone back to standard preload on front ... 38mm feels too flighty to me... Having now compared them both.
  18. exuptoy
    I still need to drop the front of mine but it's a ball ache to get the tools in there as I like to torque things up properly and my torque wrench won't fit in the fairing area.
  19. Mr OCD
    Before you do that leave the rear alone and try removing two turns of front preload and ride it ... I think you will be surprised.
  20. exuptoy
    I'll try tomorrow mate. Cheers.;)
