bar conversions
Discussion in 'General 1000RR Discussion' started by fireblade, Jul 19, 2013.
  1. Nutty Tart
    Nutty Tart Well-Known Member
    I'm sure someone will come along soon to confirm but all the legs from 08 onwards are the same diameter :)
  2. Hudson
    Hudson Active Member
    That is a decent price for them but do they come with the ' Risers ' ? The bars and risers are two separate parts, a lot of people just buy the bars and replace their standard with them, its the risers that make the position of the rider go higher and closer to the bike.
  3. Nutty Tart
    Nope ........ no risers
    I used them to get a different angle for my wrists not for the height
  4. porcpen
    porcpen New Member
    OK, thanks anyway.
    I've decided to order a pair of Apex from US.
  5. guitaryellow
    guitaryellow Active Member
    So what are the best type of bars, does anyone have experience with different makes?
  6. PeterT
    PeterT Active Member
    Yes I use Gilles they are very good, easy to adjust on the bike to get the height you want
  7. guitaryellow
    Many thanks, did you fit? Can you remember the exact model you got. Regards
  8. PeterT
    I used the Gilles Vario bars. Changed no cables and everything fitted nicely, only the hardest part was drilling the location holes for the throttle and switch gear, but I copied the original ones so that was very easy.
    I have used these for over 30,000 miles and it makes the bike easier to use over longer distances.
  9. PeterT
    I will post you a picture of mine when I get back to the UK later today.
  10. guitaryellow
    Fantastic, great stuff, much appreciated.
  11. guitaryellow
    We’re you able to use original bar end weights?
