Bazzaz ZFI and Z-AFM CBR1000RR 08-11
Discussion in 'Parts, Accessories & Clothing' started by Remal, Dec 12, 2011.
  1. dan.1moore1
    Just paid for them
    Checking on Bazzaz web site I'm getting excited about these now
    It has the self tune same as Dynojets Autotune which i could have added to my power Commander but the Fuel module controls all 8 Injectors where i would have had to buy a secondary Dynojet fuel module to get that .
    Says i can either just let the self mapping doodaa do its business , set target ratios for desired performance or get it rolling road'd to set a base mapp and then the auto tune tweaks it to the environment I'm in
  2. arthurbikemad
    All you will need to hope is the wideband sensor they supply (maybe Bosh) fits in the narrow band sensor hole in your exhaust, if not or if you dont have one you will need one welded in mate.. Never seen the AT Bazzaz so cant say what sensor they use. If its as good as my AT200 then your a happy boy.. The only thing with AT is it will only map areas that you have used, and you could argue that the self mapping is "out of time" as the correction takes place after the gasses flow by, in other words the mapping is too late on a first pass but second pass it should be mapped....if you get me... :) also I have not seen the Bazzaz software but the DJ unit is not 100% plug and play like some think you need to keep an eye on it from time to time and the safty trims need watching too as with the DJ you can set a level of correction so in my case anything over +/- 20% is not adjusted that way if the sensor fails it will not lean off the bike too much and cause harm.. I have a base map done on the Dyno and the AT keeps it in trim I can switch from base map to AT on the fly from the "as CC puts it cheap switch supplied by DJ..lol"
    #22 arthurbikemad, Dec 13, 2011
  3. dan.1moore1
    Fingers crossed .. Seller has same exhaust so will fit . I only paid 131 quid for the lot so worth a punt . Ill get a base map done and see if the tuner can spot any faults with it . Ill keep my PCV till i know its all ok
  4. CastrolCraig
    CastrolCraig Active Member
    Lol..
  5. CastrolCraig
    Will you buy the TC add on for it?
  6. dan.1moore1
    Not possible mate
    Its a different module .. Doesn't look like you can add features to any of them . You gotta go for the package you want from the get go
    Iv won this 1
    Compared to the TC one
    They sell a quick shifter only which i can add as it is stand alone or i can buy the hole kit which has the lot and you can choose race or road shift
  7. CastrolCraig
    Hmm, you gonna see how this runs then consider the whole package, i would have thought you could punt this on fairly quickly if you do?
  8. dan.1moore1
    Yeah thats the plan mate . Ill see how well it performs controlling all eight injectors and take the plunge on the full set up next summer
    I paid 131 for it so should sell it on for what i paid and more
    Paid 140 for my PCV which i have all the box for in mint condish so sell that for a profit as well and we should be half way there
  9. Gums
    Gums Active Member
    can you let us know what you think of it when it's on please Dan ?
  10. dan.1moore1
    Yeah will do mate
