Bike Cleaning
Discussion in 'Maintenance' started by ROBBO cbr, Jan 12, 2018.
  1. Lozzy
    • Funny Funny x 4
  2. ROBBO cbr
    ROBBO cbr New Member
    haha snap!! I have to leave an extra 30 min early just so I've got time to do it once at work
  3. PauloHRC
    PauloHRC God Like
    See its not just me Lozzy......the southerners are no different!!
    What products you using Robbo?? Joking!!!;)
    • Funny Funny x 2
  4. ROBBO cbr
    A tin of hair spray a time I know that.
  5. nigelrb
    Always one prepared to help the boys, why don't you send Bradt a PM; I'm sure he has a great remedy for 'helmet hair'!!:D:D:D
    • Funny Funny x 2
  6. Lozzy
    Sweet mother of god!!! What's happening to men these days :eek:
    I'm going to chuck my dog clippers under the back seat & give you all a 'proper man's' no1 :cool:
    • Funny Funny x 2
  7. CBRGav
    CBRGav Active Member
    Quick detailer either meguiars or AD whenever it's dirty. Done in the shed then waxed if needed. Only washed with water twice as got laminate in the shed and don't want puddles fair weather rider tho so never gets too dirty tbh.
  8. Leeb
    Leeb Active Member
    Mr sheen? Never come across that before!
    Does it have to be mr sheen or does any other brand of furniture polish do the same job?
  9. Wozza
    Wozza Elite Member
    Mr sheen is good try muc off speed polish........ohhhh the smell.........
  10. levin
    levin Active Member
    Anyone any tips for keeping wheels clean , has anyone tried one of those repellent waxes,
    I usually clean my white wheels with wd40 as it takes the chain grease off easily but they are covered in dirt again after 1 spin ,
    Joys of white wheels :(
  11. nigelrb
    Hi Levin. As a fellow 'white wheel owner' and persistent cleaner (OCD?) I understand your problem!!
    A preventative measure is to not over lubricate the chain. Inevitably, we get 'fly off' but if we're using a quality lubricant (I use WD 40 Chain Lube: https://wd40.co.uk/wd-40-specialist-motorbike/chain-lube/ ) more stays on the chain than on the rear wheel.
    I ONLY use Mr Sheen for the wheels. As a polish and waxer, it leaves a wax finish that makes subsequent cleaning a simple matter. By using WD 40 to clean wheels, you are removing any wax or polish you've previously applied. Just stick to Mr Sheen and you'll be rewarded!!:)
  12. PauloHRC
    PauloHRC God Like
    Or......use wd40 to get the oily crud off, buff it dry and then use Mr Sheen to give that polished feel that dust and dirt won't adhere too!!
    Just sayin ;):D
  13. Lozzy
    Use this chain lube....best stuff there is!
    Absolutely no fling whatsoever. This means you can simply wipe your wheel with a damp cloth. Then as the fussy fannys have mentioned above....just polish with Mr Sheen.......I find my wheels are going too fast for anyone to notice tbh :rolleyes:
    • Useful Useful x 2
  14. nigelrb
    Thanks for the recommendation, Lozzy.
    I've just ordered some for my 'slow' wheels!!:D:D
  15. Lozzy
    You won't be disappointed. It's superb. Needs applying a little more often than some others but well worth it
  16. levin
    levin Active Member
    Thanks will give the Mr sheen a try after cleaning with wd40 , I'm currently using that wd40 chain lube , I used to use chain wax , which was good but I didn't have white wheels at the time
    Thanks lozzy iv seen the wurth chain lube mentioned before I must give it a try
  17. CBRGav
    Wurth chain lube is awesome. Can literally spray on before going out and it doesn't fling! I always do mine when I get home tho but it never drips or splatters anywhere. Highly recommend it
  18. Gravel trap
    Gravel trap Elite Member
    I've been using muc off chain lube but it goes everywhere.i wash with autoglym as I've stacks from old job and Polish with the same. It's been medical cleaning wipes on the wheels then done. Need to get some ace stuff as use bike every day DSC_0046.JPG DSC_0046.JPG
  19. Unity
    Unity Active Member
    When you clean your bike, do you spray the whole thing (hose pipe and finger, not high pressure) or do you specifically wipe fairings and mirrors and dash, avoiding getting water on wiring and on the radiator and bolts etc where it might cause corrosion?
  20. nigelrb
    I never use a hose. Just damp cloth if there's road grime, and then Mr Sheen.
