Bike feels wooly, new Ohlins i think
Discussion in 'General 1000RR Discussion' started by PeterT, Aug 9, 2011.
  1. JM1
    JM1 Active Member
    I have to say I'm surprised we're having to explain this. I assumed everyone on here would already know the basics on tyre pressures.
  2. PeterT
    PeterT Active Member
    Seems that is not the case? I am going to try my suspension changes but i am hemmed in at the moment with this damn stupid cycle ride which is blocking my way out until 2.45pm !!!
  3. Gregr
    Gregr Active Member
    Having just checked both Pirelli and Bridgestone websites the tyre pressures for Fireblade fitment are all 2.5(36psi) 2.9(42psi) bar front/rear. There is obviously a valid reason that both of these manufacturers give these pressures, It is because that is the pressure at which the tyres work the way they are designed to do on the road.
  4. flatstickHRC
    flatstickHRC Active Member
    Like I said before the reason they give those pressures is to provide a tyre which works for more than one person in more than one environment. They are to suit someone who rides solo or with a pillion in rain or dry in temperatures just above freezing to 35degrees on a hot sunny day. They are designed to get the maximum mileage, best fuel economy and wear with a sacrifice for maximum grip or warm up.
    It's a compromise to fit all situations - not the situations most of us recreational bikers actually ride in.
    For a sportsbike rider on twisty roads riding solo on a dry day those pressures are not ideal.
    34f 36r is good rule of thumb for fast road riding.
  5. PeterT
    Right i have had a good ahrd ride and now the front suspension is nigh on perfect given the set up, increasing the oil height by 3mm has stopped the front from diving into bends which has made the bike more stable and does now feel vey planted when exiting corners with power. The rear is still a little unstable but is more controlled now. So i will try a few more changes with the rear to see if i can balance this out.
  6. PeterT
    The specs i am running in the forks is 5 weight Silkoline synthetic oil, fluid level is 90mm from top which equates to 535ml.
  7. flatstickHRC
    Did you alter the sag settings?
    What did you change on the damping front and rear?
  8. PeterT
    Yes, i now have set the front to 30mm sag with rider, rear was possistion 3 on the shock which equates to 31mm of sag. Damping is as i quoted initially as my notes are in the garage and i have painted my floor so cannot retieve them now.
  9. flatstickHRC
    Ok cheers
    I went up 1 ramp to position 5 on the rear to get 30mm and have 35mm on the front. I can go softer on The front as Im not using all the travel.
  10. PeterT
    I weigh 13.5 stone with kit so i found it better to use the lower rear peg setting as the rear shock cannot respond well to compression settings, giving a hard and un controllable rebound rate which upsets the front. So i am running a slightly softer rear end to compensate for the balance between the two.
  11. JM1
    JM1 Active Member
    Did you not read Flatstick's post then?
    Which road?
    What are the weather conditions?
    Is this with a passenger or not?
    etc
    etc
    Also, do you find it strange that all the bike and tyre manufacturers will tell you exactly the same pressures?
  12. zeepony
    zeepony Active Member
    Wowsers, I cant wait to see you guys knock a 10th of a second off you're laptime to Tesco's and back ;)
  13. flatstickHRC
    Dunlop now tell you their tyres are designed for lower pressures for grip and performance OR 'normal' higher pressures for twos up riding, milage etc etc
    For example I have a ford focus and the owners manual has about 5 different advised pressures for the same car depending on how many passengers, baggage in the boot, exceeding 90mph for a pronged period.
    Each situation has a different preferred tyre pressure.
    The bike manual recommending 36 42 is tryingto cover all bases but not the ones I want covered which is why I run 34 36
  14. JM1
    JM1 Active Member
    I couldn't agree more, I'm just in this thread for the theory and educational value! You have to admit those supermarket car park speed bumps really do upset the suspension though ;)
  15. flatstickHRC
    What a bizarre thing to come out with.
    If you don't want to improve things or get the best out of them you should just crack on with the standard concrete Dunlop qualifiers with 42 pound in the rear.
    it's not about knocking time of my trip to tesco. It's about wanting as much grip/confidence out of the bike on a given road condition.
  16. JM1
    JM1 Active Member
  17. flatstickHRC
    Well he will knock 0.6s of his trip to tesco then inthat case
    Better save your club card points as they're expensive though
  18. zeepony
    lol. Personally, i've got better things to do than calibrate the air temp, road temp, traffic density and humidity in order to re-set the values of my tyre pressures every 20 minutes.
    I just get on the thing and ride it.
  19. zeepony
  20. JM1
    JM1 Active Member
    Lol. On a race bike maybe, not sure about a track bike.
