Bike won't start
Discussion in 'General 1000RR Discussion' started by Scott, Feb 27, 2015.
  1. felek01
    felek01 New Member
    hi all i have the same problem my bike dont wont to start after off at snett last weekend the fuel pump dont even prime but engine turns ok any ideas many thanks
  2. Colonel_Klinck
    Colonel_Klinck New Member
    I had exactly that problem after my off at Brands at the weekend. With mine one of the loom plugs had partially come out of the ECU. Clipped it bac in and boom she fired right up. If that isn't it it will be a connector or damaged wire somewhere.
  3. Colonel_Klinck
    Scott you have double checked the HM earth haven't you? Does the until display when you turn on the ignition? Does it show "shift" when you apply pressure enough to change gears to the lever with the ignition on?
  4. felek01
    felek01 New Member
    i have heltech gear indicator and when i turn the key itl go up and down the gears then flashes 3 long F then 1 but i have no clue what this mean?
  5. Colonel_Klinck
    It might be picking up a fault on the bike but I've never seen that before. Email Healtech. Check all loom connections.
  6. Scott
    Scott Active Member
    It didnt power up no mate. Took otto hm today they test it and it worked so I will fit soon and hope it works. Must be my silliness
  7. Scott
    Scott Active Member
    She runs. Combination of needing new plugs bike falling over and always now use the negative on battery as a earth for quick shifter
  8. sps170373
    Glad you got it sorted
    • Friendly Friendly x 1
