Brembo 19 RCS Master Cylinder Fitted
Discussion in 'Mods, Upgrades, Accessories and Products' started by Jamiestrada, Apr 21, 2012.
  1. Bobmg
    Bobmg Active Member
  2. Bikeracer1098
    Bikeracer1098 Active Member
    Thats the one fitted to my bike !!!
  3. Bikeracer1098
  4. Bryan01
    Bryan01 Active Member
    Old Thread I know but!
    Jamie what's the sequence for position of brass washers (why 4)?
  5. chrisopotamus
    chrisopotamus Member
    To add to the old thread..my 19RCS turned up today! :)
  6. si1000repsol
    If I recall the banjo was too long and prone to leaking so 4 washers were needed to make sure it never leaked
  7. sps170373
    You're better off cutting the bolt down than using extra washers or get a titanium banjo bolt from racebolt as they make them for the brembo master cylinders
  8. chrisopotamus
    I bought a banjo bolt from Hel performance. I called them before I bought it and they said they had never heard of fitment issues.
  9. sinewave
    The Brembo RCS Banjo bolt has a slightly different pitch to it's thread compared to OEM one's.
    You're best using the correct length using the minimum of copper crush washers.
    It's not a good idea to stack crush washers against each other.
    You should use 2 if one line is leaving the RCS and is then split further down the line and 3 if using 2 direct caliper lines as most Track/Race bikes use.
  10. lambchops
    lambchops Elite Member
    If you use two lines from the master I guess there are no issues or is the bolt provided only a small single size?
  11. chrisopotamus
    I just came back from checking everything out before removing the old master. The HEL lines are about 1mm smaller in height than the stock lines connector so I was a little worried about the banjo bolt after reading there are issues with it's length. If you had two HEL lines on the master it's going to be about 2mm shorter hence maybe why people are having issues with the Brembo banjo bolt.
    I ordered the banjo bolts from HEL and I'm using a single on the master. I screwed the HEL single banjo all the way into the master without a line and from the master to the underside of the bolt it measured 9mm and with the stock line installed it measured about 13mm so should be no issues with the master and HEL lines with a HEL banjo!
    Didn't want to drain all the fluid just to find out it doesnt fit.
  12. chrisopotamus
    Supplied is a dual banjo bolt and this is what people are having issues with.
  13. lambchops
    Ok thanks Chris, will get one from Hel then as that's the lines I have :)
  14. chrisopotamus
    I'm 99.999% sure it will fit with no dramas but won't know 100% until I have done it. Nearly 4 mm difference from where it bottomed out with no lines vs stock lines and if the HEL line is only 1mm shorter than stock it should be fine.
  15. sps170373
    Hmm titanium, these aren't the droids you're looking for ;)
  16. lambchops
    Yes good point Steve :) racebolt did you say? Happy new year btw :)
  17. chrisopotamus
    Replying to my own post lol.
    Confirmed 100% the HEL single banjo fits fine with the HEL lines. Pain in the arse location though!
  18. sps170373
    Standard Hel banjo for cbr1000rr won't fit brembo master cylinder as threads are different! Know already as as my banjo for my Hel lines didn't fit me brembo mc
  19. chrisopotamus
    That's why I bought the HEL M10 x 1.0mm thread pitch one :)
  20. sps170373
    Yep racebolt do titanium Banjos for brembo items, you can also find some on ebay too
