Brembo 19 RCS Master Cylinder Fitted
Discussion in 'Mods, Upgrades, Accessories and Products' started by Jamiestrada, Apr 21, 2012.
  1. BladeRR8
    BladeRR8 Active Member
    Did you still get the ABS module cutting in when required Colin ? and if yes did the cut in threshold alter or change ?
    I have heard if the replacement m/c is too big the pressure build up can be too greater and stops the ABS module relieving the pressure as it can't relieve the pressure quick enough to stop the front locking. If the above is true the reason for this I assume is the greater pressure generated by the larger m/c means the ABS is seeing more pressure than its design parameters.
    As far as I can make out a lot of people who have fitted a Brembo RCS m/c have been advised to go for a small piston size like the 17 RCS or 15 RCS with which ever is closed to the OEM piston size but unless I m being thick (easily done) if you keep the same piston size then what gain are you making ?
  2. arthurbikemad
    The gain with the RCS is the adjustable fulcrum, it changes the characteristics of the lever, or the feel. Plus brembo engineering.
  3. BladeRR8
    Cheers for the comment Arthur.
    TBH if there is no performance gain other than feel I m going to save my money
  4. Mazzy
    Mazzy Active Member
    Excellent thread guys I was looking to purchase brembo RCS19 m/c + res, HEL lines & m4 callipers. you guys have done all research & I know exactly any probs involved & solution. :)
  5. scooboo81
    scooboo81 Member
    This is the connections on the micro switch loom that came supplied with my brembo RCS19 brake master cylinder, but they are not compatible with the honda connectors? Anybody else here has this issue? I know the connectors I require are a "blade" type, but I don't know anything about electrics.
    Any help or advice would be very much appreciated.
    Thanks!
  6. rodders4legs
    rodders4legs New Member
    Mazzy, send me a pm I've sorted a few lads out on here and should be able to help with all the bits
  7. graemewalker
    graemewalker Elite Member
  8. lambchops
    lambchops Elite Member
    I also used the assocaito MC bottle which works great with the brembo MC and is cheaper than the brembo version :) Mike at BDS is your man for these!
    Brake & Clutch Fluid Reservoir Kit
  9. rodders4legs
    But at £35 is still a lot for just a plastic pot lol
  10. lambchops
    Comes with the bracket to :)
  11. rodders4legs
    Hahaha makes it totally acceptable them
  12. lambchops
    yes but cheaper than the Brembo version thats my point :)
  13. rodders4legs
    Yeah I no what your saying,
    I've got one I'm fitting on my k4 1000 track bike next week, going to try and use the original pot
    But I'm able to get 19rcs with resivior kits for £250 delived to a uk address at the min so really tempted to get one for the blade :)
  14. Slick
    Slick Elite Member
    I used a ladybird reservoir mount with the OEM reservoir , tenner on ebay
  15. rodders4legs
    Ladybird mount ? Any links
  16. Slick
    Slick Elite Member
  17. rodders4legs
    Will see if I can use the one already on the gixxer if not I'll
    Give one a go :)
  18. kev.b
    kev.b Well-Known Member
    Also got my bracket from Projection Components :D
    They are cheaper on there website . No ebay fees to pay
  19. rodders4legs
    Some nice TI on there too :)
    What throttle is that ? And clipons
  20. kev.b
    Harris clip ons , Active quick Action Throttle
