Brembo Master Cylinder Group Buy............
Discussion in 'Mods, Upgrades, Accessories and Products' started by Bikeracer1098, Sep 12, 2011.
  1. fisher
    fisher Active Member
    Somthing to factor in guys, your standard hose will not fit a Brembo [from Cylinder to reservoir] so you'll need to buy the res-lit
    Brembo are around £48 including Reservoir bracket
    Or Goodrich are around £35 including bracket
  2. tonyblade
    tonyblade Active Member
    Bollocks! So if you get the rcs and brembo bracket for reservoir it's £300. Is that right?
  3. tonyblade
    Hi fisher, so the standard reservoir can't be used with the brembo rcs? Is that correct.
  4. fisher
    Sadly not mate, the outlet of the Brembo cylinder and the reservoir is a lot smaller than the standard
    #24 fisher, Sep 15, 2011
  5. tonyblade
    Thanks a lot for your reply, it just keeps getting dearer doesn't it. Lol.
  6. fisher
    But worth every penny mate, we all buy "Cans" for the noise, and maybe limited power increase.
    Fitting a Brembo really does transform the braking
  7. Rp1
    Rp1 Active Member
    Incorrect
    i have used the standard reservoir on my RCS
    had to make up a bracket and get a new pice of hose to fit from the res to the mc with cost pence!!
  8. Bikeracer1098
    Bikeracer1098 Active Member
    Hi Rp1
    Thanks for the info.
    Please could you post a picture illustrating the bracket and new hose.
    Also please would you include dimmensions of the new bracket
    Many thanks
    Rich
  9. Rp1
    Rp1 Active Member
    Yep no problem, i'll sort some out for you
  10. Rp1
    Rp1 Active Member
    A couple of pics to give you an idea of what i done
    A pice of aluminium cut and bent with holes drilled in places then sprayed
    may not be to everyones liking but it looks ok and dose the job
  11. tonyblade
    Does anyone know exactly how much I'm looking at then for the rcs, reservoir and bracket? Thanks.
  12. Bikeracer1098
    Any of you guys fitted the BREMBO MC19x18 or 19x20?
    I know flatstickHRC fitted the Brembo MC 19x18 recently, anyone else?
    Searching on the internet has highligted the requirement for a new bracket for the Brembo RCS, however not sure whether the fixed ration MC's (19x18 etc) require a new bracket or whether the original Honda bracket will fit!!!
    Will make some telephone calls tomorrow.
    I'm going to go for a fixed ration 19x20 MC rather than the RCS, as I don't think that I would use the flexibilty of being able to vary from 20 ratio to 18 ratio!!
    #32 Bikeracer1098, Sep 15, 2011
  13. Andrew
    Andrew Active Member
    If I was to join in with this I don't really know which one I need being you've now given us options!
    This is probably a really stupid question but can my current levers still be mounted with a different master cylinder?
  14. fisher
    No they cant Andrew.
    I fitted the 18/20, the good thing about these Brembo's are they'll fit any bike, so when you sell fit the standard jobbie and put the Brembo on the new bike
  15. Andrew
    So I take it the unit will come with a lever then?
  16. dan.1moore1
    Is that the correct type of rubber hose to be resistant of the fluid corroding it ? Does it sweat at all ? The HRC receiver kits have a thin pink tube for the front that must be designed for a brembo as it was to small for my standard mc . the kits are 20 bucks on ebay
  17. scratcher
    scratcher Active Member
  18. Bikeracer1098
    Scratcher, thanks for the info, I was just looking at their website yesterday with regards to brake pipes, p clips etc
    Motorcycle Brake Accessories @ moto-racing.co.uk
    Just tried to call them regarding master cylinder bracket and group buy etc but phone kept ringing & ringing....................................will try them again later !!!
  19. tonyblade
    If you do get through bikeracer maybe try them on a group buy?
  20. PeterT
    PeterT Active Member
    Looking at the master cylinders available the RCS is the only one with a brake light switch, so if you go for the standard MC you will also have to factor in a brake pressure switch.
