Brembo RCS
Discussion in 'Mods, Upgrades, Accessories and Products' started by Mr OCD, Apr 14, 2016.
  1. DCB
    DCB Active Member
  2. Slick
    Slick Elite Member
    When you bend into shape made sure the bolt is tight. Any movement of the mount in the bolt will scratch the RCS!
  3. Mr OCD
    Mr OCD Well-Known Member
    Any pics of yours with this mount?
    Cheers for heads up.
    I think I should have ordered the 75mm not the 95mm!!
  4. sps170373
    You're better off using the top yoke bolts to hold it, as you can easily damage the mc bolting it to it
  5. Slick
    Slick Elite Member
  6. Mr OCD
    Good idea ... Any pics? :)
  7. sps170373
    Will go and get one for you
  8. Mr OCD
  9. sps170373
    Used a ladybird bracket same as slick can't remember length but just drilled out bottom hole for top yoke bolt
    #29 sps170373, Apr 17, 2016
  10. Mr OCD
    Thanks Gents. Yoke mount it is!
  11. stevet
    stevet Active Member
    nice dash.....any pics of it lit up?
  12. sps170373
  13. stevet
    owww....like
  14. raphael
    raphael Elite Member
    Rest of the bike isn't bad either:D
  15. Mr OCD
    It's arrived ...
    Along with the bracket, pipe and clips (genuine brembo) ...
    What did people do about the microswitch... the connectors look weird!
  16. Mr OCD
  17. Mr OCD
    All done :)
  18. Noste500
    Noste500 Active Member
    How did you solve the brake light switch ?
  19. Mr OCD
    Temporarily just stripped wires back on micro switch side ... Pushed home into OE connector and taped up ... Works fine.
    Tomorrow I will pick up some small spade connectors to crimp on to micro switch side and tidy it all up ...
  20. Mr OCD
