Broken Swingarm
Discussion in 'Maintenance' started by ignatius, Aug 21, 2020.
  1. Jez
    Jez Senior Member
    Mine to hence the rant, but only the swing arm on this bike
  2. Slick
    Slick Elite Member
    Agree, I only used the swing arm bobbins to adjust the chain, everything else the warrior stand.
  3. ignatius
    ignatius Active Member
    Sorry , they are already sold :), as said one of it still stuck to the broken swingarm.
  4. ignatius
    Looks like the previous owner had a fall and broken it, the seller told it might be due to overtightening the bobbin.As its already broken and hanging , i tried to remove and it came off or might be due to my popeye biceps ;)
  5. ignatius
    Finally got hold of a good looking swingarm and should be delivered today. Decided to fix it myself . How difficult is changing the swingarm, any special tools needed. While doing this, is it worth to do any other jobs, obviously good chain and sprocket cleaning, look for coolant levels, brake pads etc etc...
  6. Boothman
    Boothman Elite Member
    Never done it but I’d imagine the biggest issue is supporting the bike as all the stands either pick up on the swing arm or its pivot point - or am I wrong (again :D)
    • Agree Agree x 2
  7. Ian E
    Ian E Active Member
    I think you will need to split / rejoin the chain if replacing swinging arm. It would be worth replacing chain & sprockets at the same time if they are worn.
    Cheers,
    Ian
    • Agree Agree x 2
  8. Black & White
    Black & White Well-Known Member
    I don't think the chain needs splitting. Just make sure you put the chain in before fitting the swing arm pivot!
  9. Blade runner 1
    Blade runner 1 Elite Member
    Never removed the swingarm myself, but the chain goes through the swingarm so will have to be split. The swingarm bolt looks like 27mm with the nut on the other side is 32mm. Also check the bearings in the suspension while you’re at it, the bottom shocker bearing can dry out and collapse.
    As mentioned, supporting the bike could be an issue.
  10. Trackit
    Trackit Active Member
    I've had the swingarm off, not a big job really, I have an ABBA skylift though, great bit of kit
  11. Black & White
    Oops. My bad re: chain.
    Deffo check shock linkage bearings. They have an uncomfortable life!
  12. ignatius
    Thank you all for the inputs .Found a video on the youtube , might be helpful. Chain goes through the swingarm and needs splitting. I have a warrior lift stand for support and should be fine in replacing the swingarm. Also i need to procure proper tools to do chain splitting and my 150 piece halford kit hasn't got all the things needed.
  13. Keeef
    Keeef Active Member
    If your chain is still good split at the riveted link and replace just the link. If not, replace chain and sprockets.
    I use this tool: AFAM Motorcycle Bike Drive Chain Riveting Press Tool for DID, D.I.D, RK, CZ & JT (Auction Site Arr No. 223017153548) as its easy to use and always gets the riveting correct.
    Hope it goes well for ya:)
