C-ABS system bled successfully
Discussion in 'Maintenance' started by samd1985, May 10, 2013.
  1. sinewave
    I seem to remember that there is something 'Brake' related situated behind the exhaust headers?
  2. barry107
    barry107 Active Member
    Yep, the front c-abs power unit, which you can see just above the oil filter below.
  3. thezipsteruk
    thezipsteruk Elite Member
    The placing of that unit is mental...its so hot there!
    It like having your cock in your armpit!! :eek:
  4. barry107
    I agree, you couldn't place it anywhere hotter or more awkward! As someone else has mentioned, if only the bleed valve was facing outwards instead of inwards, you wouldn't then need to remove the radiator or the exhaust system to bleed it :mad:
    I've got some silver reflective tape somewhere; I turned the place upside down looking for it, could I find it, could I f*$k :rolleyes: Might have some lerking about at work.
    #44 barry107, Jul 29, 2013
  5. barry107
    Poorly designed location due to massive heat transfer and also for poor ease of access for servicing/bleeding. My bike hadn't covered more then 4,000m before i started to get issues. I beleive the heat transfer speeds up the brake fluid degradation massively compared to a non c-abs equipped bike.
    Mr Honda must of let the YTS lad's loose on it, not you would have thought on their top flight sportsbike. After all the r&d that went into this c-abs system, they could have easily located it elsewhere.
    #45 barry107, Jul 29, 2013
  6. Swiss T
    Swiss T Active Member
    What a great cabs knowledge base this is becoming; well done!!
  7. barry107
    I've learnt a lot about my Blade thanks to this here forum, there are some very knowledgeable people on here aways willing to help out with advice.
  8. sinewave
    Unfortunately it's been 'forced' on us by such a shocking design! :rolleyes:
  9. Tanush Pothuganti
    Tanush Pothuganti New Member
    hey sam i got abs problem too. can you post some photos on how the shot the ABS connector i got your manual but didnt understand how to shot the connector
  10. Boothman
    Boothman Elite Member
    He’s not been on for 7 years so wouldn’t hold your breath for a quick response
