cabbie's M.I. 900
Discussion in 'Mods, Upgrades, Accessories and Products' started by cabbie, Aug 10, 2011.
Thread Status:
Not open for further replies.
  1. cabbie
    cabbie Guest
    Yes mate, I watched the shoot all afternoon! get streetfighter mag (November) My bike is on the cover and the beautiful Paige is inside all over the bike. lol
  2. dan.1moore1
    Awesome .. Must be great to see your creation being admired like that
  3. Si.
    I can't see a bike....FAP! Lol!
  4. kev.b
    kev.b Well-Known Member
    Hi cabbie ! Get yourself a AC DC tig welder it will save the trips .
    I can show you how to tig weld.
  5. cabbie
    cabbie Guest
    Hi Kev, I'd love a TIG but the tiny workshop I have just can't take it, I'm climbing over stuff as it is!
  6. kev.b
    Bike looks great ! Have to pop around again soon.
  7. CastrolCraig
    CastrolCraig Active Member
    CCome on, tell the truth here Cabbie, did you sniff the seat afterwards?
  8. cabbie
    cabbie Guest
    Kin right I did!
  9. dan.1moore1
    LooooooL
  10. Nutty Tart
    Nutty Tart Well-Known Member
    gutter .. out .. minds .. get .. of .. your .. the
    Rearrange the above words to make a well known phrase
  11. JD
    JD Active Member
    Just picked up on this thread, crikey, can I have your autograph? :clap2:
    JD
  12. cabbie
    cabbie Guest
    I spent the afternoon working on the frame lower sections
    Bosses welded in place and rubbed down
    Still had to make a few tiny adjustments to the frame welds but it's perfect now, it even holds the headstock in place the fit is that good :)
    I cut and folded the back and side of the lower frame rails
    Then ground both smooth, bottom rail ready to be welded
    It'll look good me thinks!
  13. Remal
    bloody hell that's looks good./ just wish I had the confidence and tools to do the same. and knowledge
  14. dan.1moore1
    Wow thats made a huge difference .
  15. cabbie
    cabbie Guest
    How do you know you can't do it till you try! I only have an angle grinder and files :)
  16. JD
    JD Active Member
    And a shit-load of knowledge, and patience, and a can-do attitude and .............and a few bob to buy the bits ;o))
    JD
  17. cabbie
    cabbie Guest
    Another big step forward today.
    Cut the knee angles in the frame
    And plated up
    Headstock welded (there is more frame work here to come)
    All welds rubbed down and frame fitted, forks are dead straight and all seems in line, so far so good :)
    The bar above the swing arm is just for support till I know where it's actual position will be, next job is make and fit the rear shock.
    Still exciting in it :)
  18. dan.1moore1
    Its hard to believe that started out life as 2 peaces of box section
  19. Rp1
    Rp1 Active Member
    Thats coming on great, well done keep it up
  20. tonyblade
    tonyblade Active Member
    you sir, are a god.
Thread Status:
