cabbie's M.I. 900
Discussion in 'Mods, Upgrades, Accessories and Products' started by cabbie, Aug 10, 2011.
Thread Status:
Not open for further replies.
  1. cabbie
    cabbie Guest
    Heres the bottom linkage mount welded on
    Now I was going to just weld a piece of 2x1 box section across the frame with a bracket for the top mount BUT where is the bling in that! so I've designed a fully adjustable top mount for ride height, I've ordered the materials and will be making it this week, it's a bit complex so might take a few days.
  2. dan.1moore1
    looks good
  3. ColinBR
    Loving this thread
    Cant wait to see every new update as it progresses. It amazes me.
  4. cabbie
    cabbie Guest
    So the materials finally arrived, here's the parts I had made (streetfighterbling.net)
    I turned some bushes out of 60mm dia Acetal bar
    Here the unit together, I didn't have any cap head's so used stud and nuts to check for fit, the outer parts will fit though the frame and be welded then blended so all you'll see is a recess and allen screw head
    And with shock and adjuster
  5. ColinBR
    Aaarrrrgggggg!!!
    I'm in the wrong job. Lol
  6. Nutty Tart
    Nutty Tart Well-Known Member
    Argghhhh my eyes hurt .... they look almost toooo nice
  7. arthurbikemad
    Nice!
    Posted on my HTC Sensation with Tapatalk
  8. cabbie
    cabbie Guest
    Busy afternoon :)
    Got the frame drilled and ends welded in
    Ground down flush
    And mocked everything up for fit before welding the arms in etc
    Still exciting in it lol
  9. Nutty Tart
    The Dogs mate ... impressed with it all
  10. cabbie
    cabbie Guest
    Made a start on the engine mounts (these are NOT finished, they will be boxed from the bolt to the frame) and no the mounts are going to be made of MDF these are just the patterns to send away.
    Also made a start with the frame boxing, these are just the start and many more sections will be added as the build continues.
  11. dan.1moore1
    Awesome Cabbie ,,
    Is this your first frame build from scratch ? Just wondering how much research you have done on techniques ? Is it all your own ideas or do you have books on frame building methods etc
    It really is awesome to follow this thread , Very impressive stuff mate . It made me realise how much effort and design has gone into my bike that i take for granted .
  12. cabbie
    cabbie Guest
    First frame, no reseach but have an angle grinder :)
    Good progress.
    Got the inner rear sections welded in, blended in the top section
    Both sides blended, wet'n'dried then a little polish :)
  13. dan.1moore1
  14. CastrolCraig
    CastrolCraig Active Member
    Another question Cabbie, the inner 'seams' will they remain tack welded or will you weld all the seams up completely?
  15. cabbie
    cabbie Guest
    They will be fully welded
  16. CastrolCraig
    Forgot to say, looks immense.
    At this rate, youll be designing the next Fireblade Before Honda...
  17. cabbie
    cabbie Guest
    There is another 40 odd sections to go on the frame so loads of welding to come.
  18. cabbie
    cabbie Guest
    Got the rear lower engine mounts
    I'm going to have them welded with a 5mm gap from the engine both sides, after I slide the bolt though I'll line the sprockets up exactly then make spacers to suit the gaps.
    10mm angle for the rear set hangers
    Right hand hanger made
    And just to prove I get the workshop dirty
    I also stripped all 3 calipers today and dropped them off at the powder coater
  19. ColinBR
    Oooooohhhhh
    love it love it love it!!!
  20. cabbie
    cabbie Guest
    Update.
    Got the rear lower mounts welded on, made two spacers, 2mm on right and 21mm on left, motor is now bolted tight in the frame so I can get the other mounts fitted, I'm using studding for the engine bolts for set up and will get stainless ones made later
    Got both rear set hangers welded on
    Chain alignment is spot on
    So here's where we are now.
Thread Status:
