Yes there easy enough to do Pete if you want to buy New Head light cost about £60 to £70 and projectors from 70 to 120 depending on what type of look you want, what ever customs clearance want to put on top. Twats
hmm interesting as that site charge over 300 for the light assy. I'd like pretty much as it shows on that site, i love the look of them, the demon eyes i'm not too fussed about to be fair but everything else looks good! 6000k, white angel eyes white led strips. Do you have a rough cost and how long it would take to get? Cheers Pete
I have projector lamps 6000k and white Angel eyes here. If you want your light doing be done in 1, 2 days depending on the post man. If you need a light unit 15 to 29 days as cheap place is China or keep checking evilbay cheap light new ebay item number 360699262704
I'm having some problems with the projectors I took apart the headlight (it's much easier than I expected) and when I was unboxing the new projectors I noticed that it was loose. I thought that's how it was until I realised that the plastic/silver shroud is supposed to be screwed tight to the projector and the 4 pillars in the shroud that you screw into had broken I checked the other one and 3 of the 4 were broken on that one too. So I sent K&T an email asking for replacement shrouds In the meantime I've dismantled the kit and am trying to superglue it back together, but I don't have much hope for that working
The have 3 little screw that hold them on. May need some good silicone mate. They don't look new? Your gonna need some slim ballasts by the look of them .
They were sent new from K&T. It was well wrapped in 2 layers of plastic which is why I didn't discover the problem until I was opening the wrappings to fit them It fits an 08-11 and they have 4 small screws to hold them on. The lights themselves are pretty big, but everything else is low-profile and/or small.
Make sure they fit in light as the look off the im guessing there gonna hit the light glass when installed an adjusted right. Off them up an fit lens and see if they hit back off light cap aswell Callumw.
K&T send me 2 new shrouds with halos installed. Easy enough to swap over, but the new ones are still brittle :/ Fitted and currently in the oven re-sealing the glass I screwed the projector mounting plates back as far as they will go and for the moment there's about 5-8mm at the closest point to the halo and the shroud has about 2mm clearance at the top. Plenty of room
Hump, Just been reading the Thread on the bi xenons, are you still making them up ? if so what do you charge for 2012 1000rr? do you need the bits from my bike or do you sell the whole lot as a new unit ? Joe
Honda CBR1000RR Custom Headlight Assembly , Honda CBR1000RR Angel eye HID Projector Headlight , Honda CBR1000RR Headlight Assembly , Honda CBR1000RR HID Projector Light 2012 2013 2014
Bi Xenon Thank you sinewave, I see these before but they are 55w, got the feeling that the 55w versions were likely to be hotter and put more strain on the battery. plus at the checkout that wanna charge $629 im guessing from the thread hump might be the cheaper option ( I hope, no slur on hump , just better value for money )
