CBR1000RR 2010 bi-xenon projectors
Discussion in 'Mods, Upgrades, Accessories and Products' started by tgosai, Dec 3, 2012.
  1. dani90
    dani90 New Member
    look great
  2. lambchops
    lambchops Elite Member
  3. lambchops
  4. Keeef
    Keeef Active Member
    2020 and I've just got round to doing this modification on my '09!:)
  5. F1CT1C10U5
    F1CT1C10U5 Well-Known Member
    That post is useless without photos :D
  6. Keeef
    Keeef Active Member
    Weekend of fettling the light unit
  7. Keeef
    Keeef Active Member
    Everything packaged within the fairing. Ballasts peak at 44° surface temp after 30mins 20200511_201918.jpg
  8. Keeef
    Keeef Active Member
    Final fit completed today:cool:
    Just the beam alignment to set:D 20200519_203926.jpg 20200519_204123.jpg
  9. JRNapalm
    JRNapalm New Member
  10. Keeef
    Keeef Active Member
    The ones I fitted were KT (King Technology - Item No.232166691778) which seemed to feature on YT above most others. Also from China and I had to pay the import duty, add about £20 to the price for that.
    The pre-assembled light units save you the trouble of opening your own. However, that part is not too difficult and, once open, the projectors are then a very straightforward fit. You will still have to find the space for the ballasts, relay pack etc. and sort the wiring accordingly.
    Keep posting if you go with either option and fit them.
  11. JRNapalm
    JRNapalm New Member
    The only concert for me with these ones from china, is that I have no idea what the actual lights would look like. They say it's not DOT approved and for off-road use only, so I'm a bit hesitant if I will be blinding people on the road. Also don't really want to open my headlight unit, would rather have something to backup on if it goes south
  12. Keeef
    Keeef Active Member
    I fitted the kit to a spare headlight unit (eBay is your friend) so had no pressure to do the conversion quickly, could cut it to make room for the ballasts etc. the lenses are CE marked and I still have the original to swap back if necessary.
    Hope that's helpful Bud.
  13. Keeef
    Keeef Active Member
    The xenons stopped firing up and MoT is imminent... have to put the original light unit back in* while I fix the switching unit.
    The relay circuit has got damp and corroded the main power connections inside... 20210225_071032.jpg relay still seems to be working (can hear the solenoid) but the soldered joints have suffered...
    * see post by @Stuish:
    https://www.1000rr.co.uk/threads/new-mot-rules-headlights.40631/
    ... so probably would need to swap units anyway;)
