CBR1000RR-R SP opinions
Discussion in 'General 1000RR Discussion' started by dgr, May 11, 2022.
  1. PARADOC
    PARADOC New Member
  2. PARADOC
    PARADOC New Member
    ive sorted how to set the dash up,its pretty simple,when you know how,so im a happy bunny,im also after a rear seat cowl ,but im not paying honda prices,but i cant find any on the web for the rrr 21,ive got a powerbronze tall screeen on order,hopefully ,ill be out on the beast this weekend
  3. Wozza14#
    Wozza14# New Member
    Sold mine ...
  4. PARADOC
    PARADOC New Member
    what bike or seat cowl
  5. Wozza14#
    Wozza14# New Member
    Hi the bike found I kepted riding the R1M more...
  6. Ritchierich
    Ritchierich Well-Known Member
    I now have moved on to the 2022 Anniversary Blade. OMG, mid-range is unbelievable and the gearing is spot-on, well-done Honda for listening to customer feedback.
    Still liked the 2020 Blade but this is much improved.
    Did you buy it in the end?
    • Like Like x 7
  7. PARADOC
    PARADOC New Member
    have you changed THE GEARING (15/42) and did it mess with the TC or the QS
  8. dgr
    dgr Active Member
    I haven't changed it yet. It turns out some old recall work hasn't been done so it is booked in for that next Saturday, which is the day the 2 year warranty expires. I'll start making changes after that.
  9. dgr
    dgr Active Member
    It would be nice to try a 2020 with 16/43 final gearing alongside a 2022 to see if the changes to enhance the midrange are significant. I believe they could be retrofitted to the 2020. It is certainly possible to get revised velocity stacks.
  10. Jay Floyd
    Jay Floyd Active Member
    I got a rear hugger from eBay, a Puig one
  11. PARADOC
    PARADOC New Member
    im not to fussed about the puig hugger,why all the vents in it,it will just shower the under tray in shite,unless its got mesh
  12. PARADOC
    PARADOC New Member
    hi guys i went out on my 21 sp rrr yesterday i had great fun, ive changed my mined on changing the gearing at this moment,i quite like the fact that its a pussy cat till you hit 7grand then 11grand man its like jackal and hide,i love it,but i had a problem with the QS on down shifting sometimes it would blip and sometimes it didnt work,can you reprogram the QS yourself or is it a dealer job
  13. Ritchierich
    Change the settings in the dash, I use medium and have had no problems.
  14. dgr
    dgr Active Member
    I know what you mean about the difference between below 6000rpm and above. The contrast does make hitting the power band more exciting. I get a little frustrated when in traffic and go to overtake though. It takes more preparation than I'm used to, you often have to drop 1 or 2 gears so you can get past quickly. I changed my sprockets at the weekend to 15/42. I've done a quick test and it is definitely more responsive. No issues with the traction control but I did have a couple of missed shifts on the quickshifter, so I'll keep an eye on that.
  15. dgr
    dgr Active Member
    Second ride with the new gearing this evening. The bike is definitely more responsive, the gearing is much more suitable for the road than the stock 16/40. I found overtaking in 3rd or even 4th was acceptable, so 1 or 2 gears higher than before. The flat spot just before the exhaust valve opens is still there, but not quite as noticeable. I'm hoping a new end can with no valve and an ecu remap will sort that out (Woolich get a move on please!). The quickshifter behaved itself but the shift between 2 and 3 seemed a bit clunky when you're pressing on a bit. No problems with the autoblipper but I don't always use it anyway.
    With regards to the accuracy of the speedo, I did a rough check by noting the speed, rpm and gear. So, 60mph was 5000rpm in 4th. According to GearingCommander, the gps speed would be 56.6mph at that rpm in 4th with the new gearing, so 60mph is close enough for me. I'll do some more checks when I get a phone mount.
  16. PARADOC
    PARADOC New Member
    thanks for the good info guys,so i take it YOU can not re program the QS yourself,i had it set to med,ill try it on both hard and soft,and see if it works or not,otherwise its a trip to the dealers
  17. Ritchierich
    Dash setting are all you can do. Other thing I'd check are chain tension (Not too tight) and that the gear linkage is secure.
  18. Jay Floyd
    I changed my gearing from 16/40 to 15/43.... Change QS to Medium as mentioned above and no issues.....
    Way more responsive and an absolute weapon on Track :)
  19. PARADOC
    PARADOC New Member
    cheers ill check the chain and gear linkage,many thanks
  20. PARADOC
    PARADOC New Member
    chain is ok for tightness,tried all modes ie soft,med,hard,no diffrence,except now its playing up in all gears up,and down,its booked in on the 1st of sept for a service and to check out the QS,IT CHANGES FINE USING THE CLUTCH
