Dual headlight module finally fitted
Discussion in 'Mods, Upgrades, Accessories and Products' started by Scandi999, Feb 19, 2014.
  1. Mike07
    Mike07 Active Member
    Do you still have these?
  2. Blackness
    Blackness Active Member
    I could be in the market for one of these too if they're about !!
  3. Cbrjay
    Cbrjay Well-Known Member
    I'd be up for for as well, group buy?
  4. Blackness
    Group buy bargains, whoop whoop :) ! Im in if the price is right !!
  5. pajomad
    pajomad New Member
    Count me in too
  6. Jens
    Jens Active Member
    Good morning,
    yes I still have new modules ready for shipping.
    A group buy would be ok for me.
    5 to 10 Modules - 3€ discount / Module
    11 to 20 Modules - 4€ discount / Module
    I am sorry I cannot give more discount as I am set and test each module by myself.
  7. Cbrjay
    I'll have 2, I take it that price is in euro's? I might have 3 if the ok for cbr600rr5?
  8. Jens
    Jens Active Member
    Yes, it will work on all kind of machines with seperated high and low beam reflectors.
    Also the low beam must keep working if you press the high beam switch.
    All prices from my side are in euro.
  9. Knxwledge
    Knxwledge New Member
    Will this handle HIDs?
  10. Jens
    Jens Active Member
    No, Iam sorry. HIDs are not dimable.
  11. Jens
    Jens Active Member
    Hi Mates,
    should we start a group buy?
    Will it be handled by someone from inside UK or should I ship them one by one?
    Just need your input :)
  12. Zanshin
    Zanshin Active Member
    Hi,
    I tool my unit off the bike a while back as it was rattling about a little behind the headlight housing and I was going to fit it more securely..... now I've tried to put it back on the bike and it's not working and has no LED light showing!
    Any suggestions as to what may be the issue?
    Cheers
  13. Jens
    Jens Active Member
    Hi Zanshin, does the high beam will work as normal?
  14. Zanshin
    Yes it works fine.....
  15. Jens
    Jens Active Member
    Than the module is deactivated.
    Please follow the steps in the manual or in Post #72 to turn it back on. :)
  16. Zanshin
    I had thought that may be the case and had tried the instruction in Post #72 but no joy
    Tried it both ways - just ignition on and starting the bike....
    Anything else it may be? :confused:
  17. Jens
    Jens Active Member
    Will your low beam light up with ignition only or do you need to start the engine?
    The high beam is fully operated by the module, if the module is defect the high beam will
    not work in any case.
    So, please put your high beam switch to ON position.
    Put ignition on
    Start the engine
    Put the high beam switch to OFF position
  18. Zanshin
    With ignition only
    High beam works with module in place even though there is no led lit on the module
    Will try tomorrow and let you know.
    Thanks for the help :)
  19. Zanshin
    Sorted and all working fine again....... thanks for the help :)
    Great little gadget :cool:
  20. Jens
    Jens Active Member
    :) Your welcome!
