Foot Pegs
Discussion in 'Mods, Upgrades, Accessories and Products' started by ColinBR, Nov 11, 2011.
  1. JM1
    JM1 Active Member
    Depends on the size of your feet I spose!
  2. JM1
    JM1 Active Member
    Colin's working away on this in the background, but in the meantime, I'm going to carry on posting my thoughts here...
    My next worry is that the gear side won't work as the adjusters will presumably need to move the pegs out (ie, they get wider apart) - but I don't think the brake lever can be moved sideways to compensate?
    Or am I missing something
  3. megawatt
    megawatt Well-Known Member
    You can use Rose joint bearings on the ends of the rods mate. A lot of bikes come with em standard on gear change rod.
  4. Shameless
    Shameless Active Member
  5. JM1
    JM1 Active Member
    Cheers. It might get to the point where we'd be better just buying rearsets though :)
  6. Shameless
    This may help you, If you need any other dimmensions let me know
  7. dan.1moore1
    Thats the S.E.S Design
    You might want to add that the threaded holes in the shift rod go in opposite directions
  8. Shameless
    You may well be right, I could not possibly say whos design it is, yes the connecting rod has left hand and right hand threads. The pattern is a quality piece of kit though,
  9. megawatt
    Great drawings mate.
  10. Nutty Tart
    Nutty Tart Well-Known Member
    Etch-a -sketch for X-mas was it ??
  11. Shameless
    Good one:smile:
