Found anything good on Youtube lately?
Discussion in 'Pictures & Videos' started by Remal, May 18, 2011.
  1. kpone
    The truth about Dan!
    #301 kpone, Nov 4, 2011
  2. megawatt
    megawatt Well-Known Member
    Brilliant!
  3. slowr1der
    slowr1der Active Member
  4. Remal
    OK not a blade but feck me
  5. dan.1moore1
    Ha Ha Thats about right with this bike
  6. bladerunner2010
    bladerunner2010 Active Member
    It's actualy quite a frightening experience watchin someone raggin the nads off your pride and joy on a dyno, but also quite good to see how it can go from 0 to flat out on the dyno computer
  7. Remal
  8. Remal
    my kit car has been on the dyno a few times and I'll agree with you there
  9. dan.1moore1
    WoW Quick shifter in action
  10. tonyblade
    tonyblade Active Member
    That's just what I thought dan. Mint ain't it. How do these work, ?
  11. Remal
    from my understanding they cut the power when you shift up clutch less. blipping the throttle
    Quickshifter from Translogic: World leader for Quickshifters
    will be getting the Bazzaz with the QS, TD and dyno time in the spring
  12. Remal
    8, 40v, 400hp, 750kg
  13. Remal
    NWS
    EAT DA POO POO [AFRICA DO NOT WANT THIS SICKNESS]
  14. Remal
    one for the ladies
  15. megawatt
    I think they cut the ignition for a fraction of a second, to allow the gears to shift without closing the throttle?
  16. tonyblade
    Ah right, that vid does sound awesome so fast and at full blat! Me likeeee .
  17. bladerunner2010
    The quickshifter works with a load cell on the gear change rod, when this cell senses pressure/resistance when you got to up-change, the unit then cuts the ignition for a few milli seconds to allow the gearchange, can only be used on up-changes unlike an air shifter which can work both up and down, the air shifter actually changes gear for you at the touch of a button
  18. megawatt
    Used to use an airshifter on my drag bike, but only need upshifts on the 1/4 mile!
  19. Remal
    Any pics of this drag bike.and info. got to love them made bikes with superchargers,NOS and turbos etc..
  20. dan.1moore1
    No blipping the throttle mate . Full throttle clutch less upshifts
