Genuine High Screen now £45
Discussion in 'General 1000RR Discussion' started by NS400R, Apr 18, 2020.
  1. NS400R
    NS400R Elite Member
    It is the genuine manual. It was only around £40. I'll dig out the part number. With VJMC or similar discount at Fowlers, it will be even cheaper :)
  2. NS400R
    NS400R Elite Member
  3. stuart_g
    stuart_g Active Member
  4. stuart_g
    Screen arrived today. Tried to get old one out but can’t get the rubber nut things out of the clock surround..... how are you supposed to get the bloody things out??
    Also, what way up do you put the sun shield in. There is a strip near the bottom on one side. Does this go towards the screen or the bike?
  5. NS400R
    NS400R Elite Member
    Strip is a protective piece for your clock surround, so strip to the bottom.
    Getting old screen out. Read workshop manual carefully. Remove mirrors and gently flex bodywork.
    To remove rubbers in screen, fairy liquid and water solution and gentle easing.
    Post pics up if you're still having difficulty
  6. stuart_g
    Think i’ll order 4 of the rubber nuts just in case i break one. I’ll use new nuts on new screen.
    thought that would be the way the sun shade went. Mine has air bubbles in the matt black piece and will be seen through screen so got to get those out before fitting too . Some times i wish i wasn’t so OCD about my bikes and the way they look.....
  7. Shutty
    Shutty Well-Known Member
    Pull the rubbers through the hole from the flat thin flange
  8. stuart_g
    Fitted it now. Thank you all for the pointers
    Saved me £16 for four new rubber nuts
