I dont know what "fab bed up for it" means??? Andy from DT has contacted Gilles direct and is told that these rearsets are a simple swap and the only thing that needs doing is the brake switch. Are you thinking there maybe more to it???
I meant to say unless they have being espically fabbed up for the job ,engineered better word I guess ,it's a north thing didn't gan to school
If the rearsets are designed for abs no problem,but non abs might have problem with master cyl the lines are tight ,tried it and I was 30 mm short on a 600 don't think 1000 will be any different as the abs is 6 lines not three so the rear comes from the front as the line is routed thru frame and engine so no play for line
