GoPro mounts - Show us yours!!!
Discussion in 'General 1000RR Discussion' started by Muffking, Dec 30, 2013.
  1. Remal
    I found this ^^
  2. Muffking
    Yeah it's not for everyday use as I'll be using the one on the headstock mostly, but it's good to have a selection of mounts during a ride out.
  3. callumw
    callumw Active Member
    If your helmet is an R-PHA 10 Plus, then you can also mount it on the chin bar :)
    If it's the older R-PHA 10, then it's top or side mount only :/
  4. Andy
    Andy Active Member
    Just mounted to the lower left hand panel with the suction cup, does pick up a bit of wind noise at speed but hardly any camera shake
  5. Muffking
    Old style RPHA10 callum.
    Like the vid Andy, which software did you use to select only one colour on B&W?
    More mounts arrived today, so as I was working on the track bike anyway I thought I would add them.
    Put one on the headstock.
    And this is the HESD plate I made for the RR5 that the mount sticks to (yes I know the cam is pointing down a bit).
    It's basically a plate with the HESD bolts running through it with a pair of plastic number plate nuts on the underside.
  6. callumw
    There's a funny/useful vid a guy in Canada did about camera mounts ... :)
  7. Andy
    Andy Active Member
    Thanks, Video software is Adobe Premiere Elements 11
    Very simple to use, has loads of pre-set filters which can all be applied on the fly
  8. Muffking
    Think i might need a better PC then as even the GoPro software struggles.
  9. Muffking
    More bits from China arrived
    and now I have somewhere to put them all :)
  10. Alblade
    Alblade God Like
    Nice lid!
    Have you got a link for the case please, I feel the need, the need to upgrade my cardboard box
    Is that a panning head for time lapse? I have a 1 hour one and 2 minute one made from a pot noodle timer.
  11. Muffking
  12. Alblade
    Alblade God Like
  13. Muffking
  14. Muffking
    The other bag arrived this week. So that's my travel bag and accessory bag now sorted.
  15. Muffking
    This is the mount I preferred at Cadwell. Similar to Colin's, but I used a J-Mount to get the GoPro to sit upright from a vertical mount.
    The J-Mount and tether.
    Here's a video from Cadwell that I cut together from all 4 mounting positions (front of nose, facing rear on tail, facing forwards on tail, top yoke).
  16. el-nicko
    el-nicko Well-Known Member
    TBH, I never feel fully confident of those stick-on mounts. I wonder why helmet makers don't produce a hat with a built-in top/front or side gopro mount. Same with bikes. One on the rear and one on the front under a removable, clip-on plastic cover would be nice. :confused:
    Nick.
  17. lukecairns
    lukecairns New Member
    I was wondering where to put it , I am going round brands hatch tuesday .... Thinking of putting a pad behind my pillion seat???
  18. Ratser
    Ratser Well-Known Member
    So those using a suction mount.
    Can you recommend a brand/seller ?
    I really want mine mounted down side so I can see the front wheel in the video too.
    Looked on eBay and they range from £2.99 to £30.
    Cheers in advance.
  19. Muffking
    Are you sure you need a suction mount?
    I used a combination of the GoPro extensions to get the cam sidewards off the tail on mine. Just make sure you attach a tether just in case;)
    Skip to 3:20 for the vid using this mount n.b. Should have pointed it higher, but gives you an idea.
  20. Ratser
    Got suction mount. Need to get tethers though.
    Cheers.
