Na. Got a zxr with pcv for the track. Blade is road only. Nice and smooth though so wouldn't be a bad starting point
Hi, i think I'm running different software, as my treshold is in %, also which blade do you have and where did you fithink the sensor also with and without the washers
2011 (pic of my mounting attached), without the washers in the end. Emailed them as I was having some issues with the sensitivity so they said to take them out and it was spot on. Not sure if my threshold was in % before the update or not so can't hold you to that one. You running android though?
You used the washers on the shift rod? Had two false's while playing with a porsche the other day while rushing the change
I have managed to ride few miles today. It did stall once at low speed but I also have managed few loud bangs from the exhaust Question , as this is my first quick-shifter what should I expect during the up-shift. Does it supposed to be super smooth or as it is with mine I can feel the gear change every time. Also what rev range is the most suitable for using quickshifter? Any one else has the sensor values in %? (Android phone).
Should be smooth (slight tug at worst). Just hear a change in revs, the higher up the Rev range the better they work. Tend not to use it lower down the Rev range or 1st to 2nd just out of mechanical sympathy, little rougher changes then.
