HEL brake lines - Group buy
Discussion in 'Mods, Upgrades, Accessories and Products' started by Bikeracer1098, Sep 14, 2011.
  1. JM1
    JM1 Active Member
    Received mine yesterday!
    Thanks mate.
  2. djmrmagic
    djmrmagic Active Member
    Can i come in please?
    Front and rear black pipes and blue banjos please
  3. Andrew
    Andrew Active Member
    I think you'll find this group buy is finished now mate, but if you pm JonnyAnnett that's the guy who supplied them at the discount price!
  4. tonyblade
    tonyblade Active Member
    Received mine richard, thank you very much.
  5. Bikeracer1098
    Bikeracer1098 Active Member
    Mine also arrived yesterday, it does look good.
    Will fit as soon as I receive my Brembo master cylinder.
    Thanks again Jonny
  6. bluekontakt2004
    bluekontakt2004 Active Member
    collected mine from th P/O today. I emailed hell, they do the clutch lines but not online, you have to phone to order them.
  7. PeterT
    PeterT Active Member
    Well................... i tried to fit mine tonight and found that the front lines have the ferrells 180 degrees out, no way can i twist the lines to get them to fit. 2 bl**dy hours and they are wrong? Even compared to the standard lines the fittings are out by 180 degrees. B*ll*cks!!!!!!!!!!!!!!!!!!!! who made these? because they sure did not check them? I now have no bike to ride in the morning as i was going to the Goodwood breakfast club meet. And before people say have you tried this and that................. yes i bl**dy have!!!!!!!
    Great product if only it fitted?
  8. Si.
    Oh dear.... I hope mine are ok...it's booked in Monday to get them fitted!
  9. Andrew
    Oops that's not good, can you not get a lift to Goodwood with a mate?
  10. Nutty Tart
    Nutty Tart Well-Known Member
    Thats why I stopped using that type of line because I have had a few lines that needed twisting to fit . I now use Venhill lines because you can nip them up when you have them just where you want them .
  11. dan.1moore1
    Yeah Venhill are awesome .. ensemble the banjos your self , position then tighten .. Cant go wrong
  12. PeterT
    Yes i agree, guess i will be going to Venhill on monday morning. Lucky for me as they are only a mile up the road.
  13. ray
    ray Well-Known Member
    Just watched Venhill's Powerhose Plus clip on YouTube.
    Got to admit it does look impressive, but I must add I have had no problems with my HEL lines to date.
  14. PeterT
    Lucky you then, cos mine won't fit in a million years.
  15. Andrew
    Aren't you going to give Hel the chance to make good and rectify the situation
  16. tonyblade
    Well I blooming hope mine fit when I try them as will be well unhappy if they've been made wrong! I was going to go with venhill in the first place but the group buy was too good a deal to miss out on. I'll let you know if they fit in the next couple of days, fingers crossed.
  17. tonyblade
    Like Andrew says I'm sure hel would redo them (if) there wrong.
  18. JonnyAnnett
    JonnyAnnett Active Member
    Hi Guys,
    May I ask are you running a standard master cylinder or an aftermarket item?
    We had this issue once before with one customer. It turned out that they where fitting the banjos incorrectly at the master cylinder. But not to worry you can easily rotate the banjo on the brake line yourself, even with it being swagged.
    You can see how to do this on our youtube site HEL Brake Lines - Voice Over Brake Line Swaging And Crimping - YouTube
    I'm sorry that you seem not to be happy, like I say its not been an issue before. And the original specs are actually provided to us by Honda UK.
    Having dealt with other brands and products, I know that the HEL lines are definately the most secure. I know people that have issues with screw in fittings failing. Also they aren't stainless.
    If you do want to talk to us, give me a call on 028 9185 9335 as per invoice and we'll be happy to advise. We are here to help.
    Cheers
    Jonny
    BikeBitsNI
    HEL Ireland
    #98 JonnyAnnett, Oct 2, 2011
  19. PeterT
    Yes i was going to give Hel the the chance of rectifying the problem i have, but i was upset that a trial fitting did not go well and i unded up coming out my garage at 1 AM!! I am indeed running the standard master cylinders and calipers. The main problem is that the upper banjo fittings are 180 defrees out on the master cylinder and you cannot fit them upside down because they foul the brake light switch and no way can i twist them without them almost collapsing. I will watch the video to see and report back. Thank You. PS this was no intention to put the company down in a public forum.
  20. JonnyAnnett
    Let me know how you get on.
    It's not a common problem.
    Cheers
