Hitachi HDSV01U HD Camera £50 Argos
Discussion in 'Mods, Upgrades, Accessories and Products' started by Remal, Jan 8, 2014.
  1. martinowen
    Ok not bad wonder what it's like bouncing around on the bike and in sun light etc
    Anyone done that yet?
  2. Skippy79
    Skippy79 Active Member
    not bad picture, sound is crap though :rolleyes:
  3. Remal
    I kept it in the case so the sound was not good. but will keep the wind noise away from the mic as per the go pro case. Out of the case I would have thought it was very good
    And Martin as I said is pretty much a go pro so as long as you mount it on a not vibrating surface it should come out well
  4. bradt
    bradt Elite Member
    Just tried to get one, but all local stores sold out
  5. Alblade
    Alblade God Like
    Got mine at lunchtime - Stock at Argos getting very thin, did a walk/bus/shop/bus/walk from Manchester to Salford to get mine
    Not opened it up yet to give a verdict - I will only be able to compare it the MK1 HD GoPro
  6. Toy40
    Toy40 Active Member
  7. Alblade
    Alblade God Like
    Opened the box now
    Must admit quite impressed with contents for the money
    Big difference over GoPro is the included Chest Harness, Roll bar mount plus the single flat mount
    Also to include the HDMI cable for playback is a welcome inclusion
    The manual is only in English and although not read cover-to-cover looks clear enough for a novice
    The one area I need to investigate is the ability to use GoPro mounts - unless there is an aftermarket adapter available I don't think this is possible - the following pic shows how the GoPro part is wider than the Hitachi mount, plus you would need to put plastic blanks in the gopro mount to stop it being compressed when you did up the mount.
    One difference is that you can use the camera without the housing, to the point where you have to remove the lens cover before putting it in the waterproof box - this could be handy at things like a wedding you want to place a camera near the service out of the way (Have got some very good footage using a GoPro for this)
    Like a GoPro you can also take timelapse images at set intervals
    For the money I think it is a good buy (from seeing other footage) - If I can crack how to use GoPro mounts all the better but as an intro camera for road recording it looks good - on trackdays the risk is a slight off and the case is damaged and you cannot (as far as I know) obtain replacement parts other than the battery.
  8. Toy40
    Toy40 Active Member
  9. rob929rr
    rob929rr Active Member
    Can't wait to see the results of these cameras, I have an original gopro hd that is 3 years old but one of these means I could have multi mount footage.
  10. martinowen
    Brad they got some at a branch about 15 miles from me, if your really desperate for one I don't mind heading down there then posting it too you if that helps
    I'm off tomorrow
  11. martinowen
    Found a video with it mounted to a bike, with sound and I'm pretty impressed!
  12. nrabey
    nrabey Active Member
    I picked up one of these at the weekend cant wait to try it out
  13. madmac
    madmac Well-Known Member
    Very tempted by this - and there is some in stock near me. Just worried about the mounts and where to put it when on the bike...Hmmm...
  14. bradt
    bradt Elite Member
    Hi Martin, thanks very much for the offer, but not that desperate to get one.
    Thanks again:)
    Brad
  15. Alblade
    Alblade God Like
    The mounting plate on the case is a standard sat nav one, so I think there are a fair few options - will post some pics / links in a bit but honestly for the ££'s go for it - keep it all mint and worse case you sell it on and loose maybe £10 - £15
  16. Alblade
    Alblade God Like
  17. martinowen
    Shame the first one won't fit the RR4-7, what did you search for Al? I will give it a go and see what's about
  18. Remal
  19. Alblade
    Alblade God Like
    All good news - so really its just get the parts to suit / fit where you want to attach it.
    That Ultimate add-ons site is really good for brackets for phones as satnav, powerfeeds etc.
