Honda hopeful
Discussion in 'New Members' started by BooMTowN, Nov 16, 2021.
  1. BooMTowN
    BooMTowN Member
    True
  2. BooMTowN
    BooMTowN Member
    Had a quick hour out today but not sure on the gearbox,it doesn't always want to go down gears.mighr have another try at the weekend..8f ot happy I'm calling honda...suzuki was silky and precise
  3. Coda
    Coda Active Member
    Hondas have a reputation for the gearboxes being the weakest part of the whole package. That said, apart from clunkyness with some of the Hondas I've had, I've not had an actual problem with the boxes per se.
  4. BooMTowN
    BooMTowN Member
    Just spoken with a friend and he insists blioping the throttle.8f revz are low...if this is right I'm learning to ride again lol
  5. gRRandeelion
    gRRandeelion Active Member
    @BooMTowN fit a Gilles gear shift shaft outrigger bearing support, set your chain tension correctly and adjust your shifter to suit then abuse your slipper clutch and enjoy your blade. (P.S. you're right, Suzuki boxes are the best).
  6. BooMTowN
    BooMTowN Member
    Thanks,I thinknill do just that...everywhere I look seems to suggest chain
  7. raphael
    raphael Elite Member
    That’s not right at all mate, the only thing with the Hondas are the big clunk at standstill into first gear, every blade I’ve had and even with 50k miles have found the gearbox to be silky smooth.
    the shaft support is a good idea and I would happily recommend racetorx for a good product and great value after using one on mine for some years now.
    Hope you get it sorted
  8. BooMTowN
    BooMTowN Member
    Cleaned and lubed the chain and took bike out yesterday,bike ran lovely so I'm thinking it's chain related
  9. ColinB
    ColinB Active Member
    Are you telling me that you bought a bike from a main dealer and the gearbox was clunky until you oiled the chain!!! As Raphael said they can be a bit clunky putting them into first from neutral and quite noisy in neutral but after that they should be smooth.
  10. BooMTowN
    BooMTowN Member
    It's not clunky it just wouldn't go down all the time
  11. BooMTowN
    BooMTowN Member
    Bike is nice n smooth,but like I said,it was struggling to go down gears,now the bike is geared so much different to the 600 I had so maybe I was to low in the box,I've read ot can be slack or unused chain aswell.as other things...if its not q00% I'll yale it in
  12. BooMTowN
    BooMTowN Member
    Had the bike out for an hour or two on Monday,once warmed up it is random as hell dropping down box Into 2nd and 1st,sometimes sweet as a nutt and others it.just won't go...I've booked.it in to honda for repair...if this is remotely normal the I can't keep it..Will drive me Batshit crazy...its fine cold but gets worse when warm..seems to suggest clutch plates.i think I read..hopefully they'll sort it and I can get back to just riding..up the box is spot on,brakes handling and power are great so no worries there...oh,I did notice that when pottering local the temp goes up quick and I'm sure something smells burny...if you know what I mean...anyway,fingers crossed again .
  13. raphael
    Sorry to piss on yer chips bud but These are the smoothest litre bikes you can get mate, I wouldn’t even waste my time looking at what it could be and throw it straight back at them as there’s clearly something wrong.
    #53 raphael, Jan 4, 2022
  14. BooMTowN
    BooMTowN Member
    It's booked in and won't be taken back until 100% or they take it back
    • Optimistic Optimistic x 1
  15. BooMTowN
    BooMTowN Member
    I've put off and put off but ot needs sorting...love the bike and don't want to change..hopefully something silly.ive every faith the local honda dealer will be as good as reviews suggest
  16. BooMTowN
    BooMTowN Member
    Bike went into honda,for nearly 2 weeks whilst they testes and tested...zero problems they say..I fitted a healtech gear indicator..under battery/fuse box,was a nightmare to find,especially as I took the front off thinking it was their lol..anyway,had anhjour out today and really enjoyed it...what a difference knowing where I am in the box..I'll pro ably be getting a new rearsets fitted..any suggestions appreciated..I've noticed the actual gear lever is further away from the frame than my old one was so find myself pushing down on the actual shaft rather than the lever,still works but annoying... 20220205_122935.jpg
  17. bazzashadow
    bazzashadow Elite Member
  18. bazzashadow
    I use putoline N-tech pro R+ and never had a problem
    And I wanted a twelve and ended up with a 16 but went for these years because of the gear indicator built in the dash
    Non abs because I done a lot of reading ;)
  19. BooMTowN
    BooMTowN Member
    Not done a million miles but brakes are very good
  20. BooMTowN
    BooMTowN Member
    Not oil no
