honda sp1 oil leak ?
Discussion in 'General 1000RR Discussion' started by keithg1748, Apr 21, 2018.
  1. bazzashadow
    bazzashadow Elite Member
    I can’t believe some of the things I read on this forum:eek:
    Come on Honda sort yourselves out.
    Think I should of brought a Ducati after all:(
  2. Lozzy
    Lol the last I read the ducatis were bursting into flames :p
  3. Demmel
    Demmel Member
  4. bazzashadow
    You need to buy one Lozzy
    We could call you hot lips then;););)
    • Funny Funny x 2
  5. nigelrb
    And you guys worry about my lounge room?:rolleyes:;)
  6. benya
    benya New Member
    Back on topic, does anyone know the torque spec for the sump bolts? Gutentight?
  7. hessel
    hessel Member
    you wont find the specs of them 2 bolts in the manual for some reason.... I torqued mine to 30nm with blue medium locktite on the threads.
    has been fine since then....
    30nm is about the limit for me when torquing steel into alloy.......specially with them fine threads
  8. keithg1748
    keithg1748 Active Member
    it is 30nm in the manual.
  9. benya
    benya New Member
    30nm? Seems very high. My Aprilia Tuono V4 sump bolts are M6x30 and the Aprilia service manual specifies 12nm.
  10. benya
    benya New Member
    I have the manual, and the spec is not listed. At least not as far as I could tell. Here is a pic of the only place I see the bolt:
  11. hessel
    hessel Member
    i couldnt find it either....
    maybe its in there but i overlooked it...
    either way, i torqued both the plug and the adapter thingy that holds the oil pressure sensor to 30nm causse thats about right for steel into alloy i felt...
    locktite on it to make sure its sealed and wont come undone again and you can forget about it....
  12. hessel
    hessel Member
    i thought we where still on about the plugs. not the bolts.....those probably take 10nm max so fingertight....
  13. keithg1748
  14. nigelrb
    On the earlier manuals there is a section which refers to 'standard torque values'.
    Not sure if this might help:
  15. benya
    benya New Member
  16. keithg1748
    fair enough I had seen it wrong.
