Honda tall screen .... F*cked it
Discussion in 'General 1000RR Discussion' started by Knighster, Oct 31, 2014.
  1. Repsol Rob
    Repsol Rob Elite Member
    Christ I better find it........ ;)
  2. Knighster
    Knighster New Member
    I did think of this as an idea but it doesn't appear that it would work as it is an adhesive backing. I may be wrong on this but i didn't think it would work.
    It's a slag of a job if you're a numpty like me!
  3. Knighster
    I've got all the faith in the world that you will! Can you come down and fit it for me while you're at it !:p
  4. RedMacGregor
    RedMacGregor Active Member
    That's how I did mine - bit of soapy water and once you have in the right place use an old credit card with a blunt edge to push the water from under the sticker.
  5. Knighster
    That's what I'll do then. Plenty of soapy water. Sorted. Cheers chaps.
  6. Hudson
    Hudson Active Member
    I would use the new sticker and make a template with it, then take this cut out and place it on the screen with a bit of blue tack..... Then as said just "draw" round the template .... Whip it off and put the actual sticker in the area marked. Not sure i would use a pencil, maybe a non perm felt pen, at least test it on an old screen first.
  7. steve b
    steve b Active Member
    im pretty sure I used window cleaner as was recommended on here and it worked a treat
  8. rocket
    rocket Active Member
    I fitted mine whilst screen on bike.. As the backing splits down the middle I lined it up first then used masking tape to hold one side perfectly in place. Then just lifted up the opposite side remove half the backing then smooth out.. Then remove the masking tape , ease up the other side then peel of remaining backing whilst smoothing out. I did find a company that made them on the net, ??? Designs rings a bell I,ll try and find the link. I bought one from them and it was as good as Hondas..
