Important Notice - Please Read If You own an ABS 2009 Onwards Model
Discussion in 'General 1000RR Discussion' started by jimglasgow, Jul 8, 2013.
  1. Kevin1
    Kevin1 Elite Member
    I would occasionally get a flashing light, but usually turning the ignition off then on resolved it. When that didn't resolve it, charging the battery helped.
    I bet in the 6 years I owned it, I only got the flashing abs light about 10 times in 27,000 miles.
  2. Dartmoor Dave
    Dartmoor Dave Active Member
    I've said this elsewhere, the owner's handbook for my 2010 says a difference in lever function may occur at low speed. I'm taking that to be where the ABS switches on/off. I believe its 8 kph or 5mph approx. I haven't experienced it at speed(thank God) but my earlier post tells of a hot day anomaly. Turning it into a Non-Abs is only a matter of removing the hoses and carefully draining all the brake fluid, closing the open rigid pipe ends with unions or plastic bungs then fitting hoses from a NOn ABS model. The difficult bit is removing all the ABS kit. I have yet to read from anyone whether the brake performance is the same because I think the front master cylinder is different? Perhaps someone can reply.
  3. Zapada
    Zapada Active Member
    So if i leave all plumbing, pumps and abs ecu connected without removing anything just closing the pipe ends i cam convert to non abs without any issues?
  4. Dartmoor Dave
    Nope, MS is the same but caliper pistons are different. According to my 2008-15 manual STD is 32mm, ABS is 30mm, rear is same for both at 14mm and caliper at 30mm.
  5. Zapada
    The front calipers on the 2012 abs model have two size pistons in each caliper. 32mm and 30mm
  6. Dartmoor Dave
    Didn't want to mislead about conversion. Its been documented elsewhere in other posts about what needs to come off. I gather you can remove the ABS fuse to turn the system off and blank the ends. Can't remember if the dash warning light stays on, though. Dig through the other posts. I guess a change in calipers would be needed. At least then bleeding would be a 5 min job. Is it really a problem that warrants the conversion?
  7. Dartmoor Dave
    Meant to say, when the dash warning light came on on that v hot day I didn't notice any difference in braking. A bit weird.
  8. Zapada
    Thats why am asking if it is a "feature" and not a problem. So it seems that the abs functions the way i have described it and is not a problem.
  9. Boothman
    Boothman Elite Member
    PM sent
  10. Slick
    Slick Elite Member
    AFAIK the calipers are exactly the same abs/non abs. both are 32/30.
    you can force non abs by simply pulling the fuse no replumb required but you will still have to sort out the ABS warning light
  11. Dartmoor Dave
    My apologies to all !!! The calipers are the same for both, they just have 2 different size pistons. I re read the stripdown and realised the error, sorry.
  12. Dartmoor Dave
    My back brake is rubbish too. Like standing on a brick regardless of the metallic or non metallic pads I've tried. Just about enough to feather for a bend or hold in traffic.
  13. Lozzy
    Just spotted this bit of optimistic wording by the salesman....cunning new tactics maybe to shift them o_O :D
  14. nigelrb
  15. Lozzy
    Tell you what, if he'd had it up for sale earlier I'd have snapped it up. There wasn't a decent non abs 16 Repsol I liked in sight at the time :(
  16. Shoddy
    Shoddy New Member
    Hi everyone, I'm a new member here - looking for a 2012+ blade.
    If I am inspecting a prospective purchase that has ABS fitted are there any checks i can do to avoid future issues? Or is it just pot luck if I pick a good one or not?
  17. nigelrb
    Pot luck from most of the posts I've read. But I haven't had an ABS bike of the problem years.
  18. Boothman
    IMHO I’d say its like running round in a minefield in big heavy shoes - not a case of if, just when
    #318 Boothman, Jun 8, 2019
    • Agree Agree x 3
  19. Zapada
    Well if it is a good deal then get it, you can remove the system when it "fails".
    #319 Zapada, Jun 8, 2019
    • Optimistic Optimistic x 2
  20. Kevin1
    Kevin1 Elite Member
    Although it is possible to remove the ABS, it is best avoided at all costs.
    • Agree Agree x 3
