Important Notice - Please Read If You own an ABS 2009 Onwards Model
Discussion in 'General 1000RR Discussion' started by jimglasgow, Jul 8, 2013.
  1. ReventonV12
    ReventonV12 New Member
    The lever is not full back to the bar mate, first it is feel solid and then soft and the lever move about 1 - 1,5cm to the bar (just sometimes when I ride in heavy traffic but I am worry about this issues). I still hope someone had use DOT 5.1 brake fluid for this bike tell his feel about the brake, is there any difference then using DOT 4 on this bike.
  2. Ian E
    Ian E Active Member
    As I mentioned earlier "I think there is something in the owners manual regarding inconsistent lever feel at low speed being a characteristic of the system". Have you got an Owners Manual with the bike? I had mine from nearly new and it was definitely inconsistent at low speed.
    I don't think the brake fluid type will make a difference. What might make a difference is doing a full bleed of the system if the fluid is 5 years old and has never been changed. The complexity of the system often means that owners don't bother changing the fluid.
    • Friendly Friendly x 1
  3. Jez
    Jez Senior Member
    I would agree brake fluid type probably makes no difference, Who said use dot 5 as I have not heard of this before
  4. Jez
    Jez Senior Member
    I have just read this
    DOT 5[edit]
    DOT 5 is a silicone-based fluid and is separate from the series of DOT 2, 3, 4, 5.1. It is immiscible with water, and with other brake fluids, and must not be mixed with them. Systems can change fluid only after a complete system changeover, such as a total restoration.
    It contains at least 70% by weight of a diorgano polysiloxane.[5] Unlike polyethylene glycol based fluids, DOT 5 is hydrophobic.[6] An advantage over other forms of brake fluid is that silicone has a more stable viscosity index over a wider temperature range. Another property is that it does not damage paint.[citation needed]
    DOT 5 brake fluid is not compatible with anti-lock braking systems. DOT 5 fluid can aerate when the anti-lock brake system is activated. DOT 5 brake fluid absorbs a small amount of air requiring care when bleeding the system of air.[7
  5. Iain
    Iain Active Member
    No one said use 5.0.
    However 5.1 is a good upgrade from 4.0.
  6. ReventonV12
    Thank you, I got the owners manual. I just ride my bike today after several days take it to a bike workshop - I feel the brake is very good than it before. The owner of workshop told me that CBR1000RR 08 - 16 he knew always got that issues like me, don't worry about it too much. And they completely change new DOT 4 brake fluid for me, now I am happy and enjoy it at weekend.
    BTW: Thank you everyone so much.
  7. Herbert J. tea3agger
    Herbert J. tea3agger Active Member
    I have had this happen with a 2017 CBR1000RR - at road race speed in tight corners in Tasmania.
    I put it down to pads at the end of their servicable life (~20000km on pads) - They had heaps of meat left but the ABS system could not handle the pistons being so far out. I have not had this problem since replacing pads <20000km.
  8. NS400R
    NS400R Elite Member
  9. Jez
    Jez Senior Member
    I am shocked Honda Have owned up to an issue
  10. bazzashadow
    bazzashadow Elite Member
    I wouldn’t take it to Norton way if they paid me
  11. Kevin1
    Kevin1 Elite Member
    This is a pic from a while ago when I had a 2012 model.
    As you can see the lever is back to the bar with only one finger.
  12. Jez
    Jez Senior Member
    Right or wrong I now naturally pump the brakes during use, It works for me, but you should not have to do this
  13. Kevin1
    Kevin1 Elite Member
    It must be easier to get to
  14. Marco blade abs
    Marco blade abs New Member
    2013 fireblade cabs whilst riding at weekend lever went straight back to bar no stopping nearly went under a wagon no warning got bike home and done full bleed went out and same again so stripped abs out put goodridge lines front and rear advice how to turn abs light off woukd be awesome
  15. Boothman
    Boothman Elite Member
    You need to earth the orange/green wire coming away from the clocks (as in not coming from the loom towards the clocks). Then when you turn the key on the ABS light will come on for a few seconds and then extinguish.
  16. Marco blade abs
    Thanyou will do in morning cheers .m
  17. bazzashadow
    And claim some new pants off honda:p:p:p:p
  18. Boothman
    All sorted now @Marco blade abs?
  19. Marco blade abs
    Yer quick update done wires lights out and brakes are perfect its now a bike I can trust thankyou for all the advice .n
  20. CBRmetasys
    CBRmetasys New Member
    A very interesting thread , mixed reviews , some hate the C-ABS , saying it’s dangerous yet others love it and have praised it for being a life saver .
