Important Notice - Please Read If You own an ABS 2009 Onwards Model
Discussion in 'General 1000RR Discussion' started by jimglasgow, Jul 8, 2013.
  1. ShinySideUp
    ShinySideUp Elite Member
    Nope, only way is removing the whole system from the bike.
  2. BEK
    BEK New Member
    Looks like a no no then :(
  3. thezipsteruk
    thezipsteruk Elite Member
    BULLSHITTERS!
  4. madmac
    madmac Well-Known Member
    Shop around. I have the same bike as you and my local Honda dealer quoted me just 2 hours labour to do it, due to the fact they've figured out a way of bleeding the front without removing the exhaust headers. I ain't had mine bled yet as it only happens very rarely on my bike - but the system is long overdue a bleed so will prolly have it done before next year.
  5. BEK
    BEK New Member
    I'm gonna keep my blade for this yr I think because I ain't payin £300 just to have the brakes bled...Maybe move on to a none ABS model or even summat else
    • Agree Agree x 2
  6. thezipsteruk
    Exactly what I did matey!
    the non ABS blade I exchanged for is 'The Mutts Nuts' I love it so much.
    Its such a shame as the ABS is brilliant most of the time then you just lose trust in it and thats why we buy a HONDA isn't it?
    Enjoy your bike @BEK
  7. BEK
    BEK New Member
    Yep that's what I'm gonna do because I'm really liking this blade apart from the ABS so I'll just ride with it for this season then move on
    Cheers thezipsteuk
  8. Dartmoor Dave
    Dartmoor Dave Active Member
    Having re read all this again I have to ask; Have all the contributors to these threads filled out a VSA /DVSA form outlining this fault as justification to order a recall or investigation? Telling everyone on this site and what they did next(Remove the system) and not getting the official department in on the game will not force Honda to acknowledge the problem. There is an online form at forms.vosa.gov/Vsdr/create
  9. Dartmoor Dave
  10. ShinySideUp
    Vosa already opened and closed an investigation which they tested Honda supplied cherry picked bikes and showed vosa the system schematic plans showing suposidly incorporated fallback system (which doesn't work properly.) this was enuff for vosa to say the system is safe and working as it should so they closed the investigation and took no further action!
  11. Dartmoor Dave
    Ok, I've caught up on all the threads now so I'm going to go quietly. I can see we are going nowhere with this so all I can say is if it happens to me on a ride out come spring there's going to be a very cheap 2 owner, low mileage Repsol CBR for sale!!
    Thanks for the replies, guys.
  12. jeff james
    jeff james Active Member
    I`ve just taken delivery of a 2015 C-ABS and after reading this thread I am scared stiff of taking it out for a ride, especially in the busy Cardiff commuter traffic. Does anyone know if the problem still exist on the updated 2014 and 2015 models?
    Thanks
  13. sp1n99
    sp1n99 Active Member
    My 2014 was fine. No problems whatsoever.
  14. Dartmoor Dave
    Somewhere in all the threads on the US/Canada side of the pond there was a piece from a guy about having an ECU changed FOC by his Honda dealer because there was a free refit for bikes exhibiting these problems. I can't put my hand on it at the moment but if anyone else has read it, it adds weight to the fact of a later upgrade. Best of all it was a dealer free fit. If there is such a scheme Honda would be hard pressed to deny it, or the problem.
  15. MPJ
    MPJ Active Member
    Is this it ?
    http://www.hondacb1000r.com/forums/cb1000r-general/12913-abs-any-issues.html
  16. Gligoric
    Gligoric Active Member
    Since I bought my Honda in Jun 2015 I noticed when ever I leave the bike for more then 5 days first touch to front brake was bad.
    Brake lever was too soft and I could almost hit the throttle with the brake lever.
    And also noticed that lever position when starting braking is not always the same.
    I bought Brembo RCS19,and again problems,too soft compare to my BMWS1000RR and SuzukiGSXR1000.
    After that I bleed brake for more than 5 times,and after all that done now looks fine.
    I never called Honda dealer in my country for this problem because they are useless.
    Example: For first service on my Honda I had to bring bike to dealership due to warranty.
    After service I noticed screws are missing from fairings and oil left on exhaust, I was pissed off and never visited them again.
  17. Dartmoor Dave
    Over Christmas I was browsing the books etc that came with my 2010 Blade and in a 20th Anniversary booklet for the CBR/RR/RA there is a reference to the operation of the brakes, and I quote; You may feel a change in the way the brake lever/pedal reacts when it is operated under the following conditions;
    Immediately after turning the ignition switch to ON
    After braking to a stop and applying the brakes again.
    It also says the ABS is switched off below 4mph / 6km/h.
    Doesn't fill one with joy, does it? But it does give a hint as to some of the faults of low speed filtering when the brakes go weird.
  18. derchef
    derchef Well-Known Member
    there are also difference in how to bleed brakes on 2011< and 2012>
    as well there is a special way
    not written on workshop manual
    not relesed to all dealers
  19. Dartmoor Dave
    I acquired from the states a Honda genuine manual, part no 61MFL07, CBR1000RR/RA/RS, 2008-2015 , and the ABS section is 9mm thick of A4 sheets!! There may well be differences but its going to take some heavy reading to find out. If I thought there was any way of publishing it to the forum I would. Could be problems with copyright though. Job for a rainy day.
  20. derchef
    i already posted the newest workshop manual in pdf
    other members posted oldest too
    (was also a template/fast edition)
