Mine has the little button to change the programming however I tried to change it today. Used a cocktail stick to depress the button and it didn't change a thing!
Is there a trick to it? I turned the key in the ignition but didn't start the engine and pressed the programming button three times. Nothing happened!!!!
the intergrated tail light itself is legal as long as its e marked, but mot book said rear indicator need to be 240mm apart so you will still need actual indicators as well (again e marked) to pass a MOT
The indicator spacing wasn't the issue when mine failed its MOT. It was to do with the LED brake lights (on the side of the indicator flashing) going out when indicating, even though the brake light stays lit on the other half.
Took mine down for its MOT the other day. The only thing the tester said was, I think they're more noticeable. So it really is down the the tester at the end of the day.
