Thanx Bryan,I,ve changed battery and the 30 fuse next to it,got nothing. Going to try and get to the main fuses now
I'm no good with electrics but someone will know the answer to this Could connecting the battery wrong like that melt a wire somewhere or is that what the fuses prevent
Unlikely to melt any wires. Have seen lots of battery terminals broken by it though. Need a wiring diagram really to see what is likely to blow but I would expect things like the ECU would have reverse protection via a diode.
Bryan,just wanted to say your a diamond geezer! Thank you..sincerely. All fixed,was the main fuse and a smaller 10 in fuse box,all others were fine. This is a brilliant site,I didn't even know about until yesterday. Rest assured i,ll be on regularly from here on. Thanks to all who helped out.
Excellent News! The site is brilliant ask a question and somebody will try and provide the answer or where you may find it!
I was going to put that my friend did the same on his MV Agusta and buggered it right up, but didn't want to set you in a panic and think the worse !!! Well done and welcome.
Scooby.. Thanx pal. If not for you the ball would never have started rollin cheers bud. And what exactly is that sign? +.......
