Kev's SP1 not a happy chappy
Discussion in 'General 1000RR Discussion' started by Kevin1, Sep 17, 2018.
  1. RC45
    RC45 Active Member
    What is the part number of your ECU?
    38770-MKF-D43?
    #141 RC45, Jan 21, 2019
  2. Slick
    Slick Elite Member
    The yoshi on my RR9 was almost as bad. used to get looks when sitting at lights. Had to richen it up a bit at idle to fix
  3. Kevin1
    Kevin1 Elite Member
    Hi Slick
    This isn't tickover, this is a low throttle held steady to set off, slowly and quietly. If you let the clutch out just as the revs drop (as you can see it's random, not a steady predictable hunting), it virtually stalls, and then requires a fistful, to save stalling. So it's not just the hunting, it's the whole sequence of events.
