Lockdown- what you done?
Discussion in 'General 1000RR Discussion' started by Paul Longstaff, Mar 28, 2020.
  1. Dave dunlop
    Dave dunlop Elite Member
    Finally got my shifter/ blipper installed to replace troublesome OE unit! Also now having a matching rear wheel:D:D
    B465784B-E2A3-4BA0-9C4E-472920D2D57B.jpeg 0E98BF2E-6B2E-4559-A3F8-FC6A8E9B6931.jpeg 4A182E1B-C499-4B73-99B9-04332994A5B6.jpeg 0DF0469A-66F5-4DE2-9996-F89B109FB702.jpeg
    • Like Like x 12
  2. Paul Longstaff
    Paul Longstaff Senior Member
    Looking nice so what you gonna do for the next week of lockdown?
    I've started casually looking at classic cars and bikes trying to work out if I could get 1 as a project but then I remember I'm shit at doing stuff like that but I can dream. Christ I cant even paint the interior of my garage like some do :(
  3. gaz22
    gaz22 Active Member
    D2BB509B-2E32-4BD7-B4FD-24D2CB43053C.jpeg B012A512-834A-4DEF-B33F-F249C58431A6.jpeg Just finished the garage refurb and finished this old thing, shame to get it dirty at some point in the future!!!!!
    • Like Like x 13
    • Optimistic Optimistic x 1
  4. Wozza
    Wozza Elite Member
    Wow garage is fantastic ....
    • Agree Agree x 4
  5. Lozzy
    Isn't it just!
    I had the exact same stool....but the castor's constantly fell off it and the metal bits holding them on bent....not sure if it was shite engineering or my fat arse lol
    • Funny Funny x 6
  6. Lozzy
    Just heard some news on't radio...
    Looks like old Bernie Eccleston has been finding something else to do during the lockdown....
    His new missus is expecting! Baby due on his 90th birthday :eek: :D
    Bleedin hell he's worse than @PauloHRC lol :rolleyes:
    • Funny Funny x 7
  7. DazK
    DazK Active Member
    But who did he pay off to be the father?:D With all the tech in F1 even Bernie can still get it hard:D:D:D Probably be born with an F1 or Merc logo on its forehead:D:D:D
    • Funny Funny x 2
  8. DazK
    DazK Active Member
    Shame that as I would’ve offered you some garage floor paint:) I’ve got 3 litres of Ash Grey floorshield going spare. Enough to do a standard 18’x9’ floor twice with a bit left for touch ups. Easy to apply via brush or roller. Unless you want to be brave??
    It’s free to anyone who’s local:)
    #108 DazK, Apr 3, 2020
    • Friendly Friendly x 2
  9. mk3golfcab
    mk3golfcab Elite Member
    Where are you based Daz?
  10. DazK
    DazK Active Member
    I’m in Newcastle Upon Tyne
    It’s quality floor paint. Retails around £70 for 5L
    I prefer the red so it’s surplus to requirements and I don’t mind helping a forum member pass some time away lol
    #110 DazK, Apr 3, 2020
    • Friendly Friendly x 1
  11. Marc
    Marc Active Member
    I've heard it's a pig of a job. Not fussed about the fairing round the headlight, it's the side panels I'd be keen to take off. Have thought about ordering a new set of fairing bolts from ProBolt before I start, that way I'm replacing them all and if I break any in the process it doesn't matter.
  12. DazK
    DazK Active Member
    Try this place? Good pricing and excellent service. I got a full set of stainless bolts for mine and included all the plastic fasteners as well:)
    https://www.speedyfasteners.com/Honda_Fairing_Bolts_Fasteners_Parts_s/1821.htm
  13. CharlieR85
    CharlieR85 Elite Member
    You won't break the bolts Marc, it's the plastic tabs that are the real danger. Snap a couple of them off in the wrong place and it will never sit quite as flush as it should ever again. There are a few videos online to help you but nothing that will make it fool proof. Here is the way I remove the fairings.....
    The lower belly pan needs to come off first, this is held in by 2 bolts on each side (4 total). Remove these bolts but keep it supported with your hand underneath when removing the last bolt. Now with all the bolts out its held in at the front directly underneath the radiator by plastic tabs. You need to move it sort of rearwards to disengage the tabs. Just go easy, it won't need any force to lift away just a bit of jiggery pokery.
    The upper fairing is bit trickier, first remove the plastic tray that sits underneath the headlights, it's called the air intake cover in the manual. Its held in by 3 plastic push pins (manual calls them trim clips). You can unscrew the centre of the pins with a PH2 screwdriver bit, with the centres unscrewed the whole body of the push pin will pull out.
    Next look at the top corner of the radiator there is another push pin on the inside of the fairing. It's about 1.5inch from the top corner of the radiator. There is one for each fairing. Remove this push pin in the same way you removed the other 3 for the intake cover.
    Now look at the intake cover directly below each set of switchgear on the handlebars. There should be one black fastener looking up at you at the front, remove this. Now put your hands on the inside of the intake cover inbetween the intake cover and the fork leg you should find 2 smaller screws one at the front and one at the back. Remove these 2 screws again with a PH2 screwdriver bit. Now the intake cover should slide rewards and be able to slide out over the fairing.
    The fairing (manual calls it middle cowl) is just being held on by the one screw at the rear of the fairing that is directly above the crank case and a myriad of clips at the front of the fairing which interacts with the upper (nose) cowl. Remove the screw at the rear and now the fairing is just being held in by interlocking clips. Don't worry though, it's still quite sturdy without any bolts holding it in, it shouldn't just fall out. This is the bit that can be a pain, you need to slide the fairing forward to unclip it from the upper cowl. Just go steady and you'll get it. Once it's out, study the clips to see exactly what needs to happen when you're re-fitting it.
    • Useful Useful x 4
  14. Boothman
    Boothman Elite Member
    Bloody good write up that - know it wasn’t directed to me but very useful. Thanks @CharlieR85
  15. DazK
    DazK Active Member
    Big ass icicle in the eye socket up to the brain, no weapon to find when it melts and no fingerprints:D not that i’ve thought about it......much:D:D
    • Funny Funny x 2
  16. MrB
    MrB God Like
  17. Boothman
    • Funny Funny x 2
  18. raphael
    raphael Elite Member
    Has to be the new tt
  19. Philip
    Philip Active Member
    Its got to be the HRC helmet ?
  20. Paul Longstaff
    Seems like some people just love peeing me off.
    Ffs.
    Dont get me wrong its stunning mate it's just....
    Well...I spent days (about 3) pulling 20 years worth of crap out of mine late last year. Spent a good few hundred quid on shelving, bench etc and WAS really pleased with myself. Then the 'garage' snobs turn up and remind me mine looks crap in comparison so that lovely internal smugness that I had is gone :(
    At least my new lights turned up and they are great, my garage is much brighter and a good investment.:D
    • Funny Funny x 4
